Thanks for the replies
I thought there was a way to de- activate the calipers , that's what I was looking for Anyway I've got it released by other means , I removed the center console and dried it out , got some 3 mm air pipe and cleared the sunroof drains , poked it down the hole then blew down it a few times , seemed to do the trick Re-assembled the console , reconnected the battery and fired it up , the switch wouldn't switch the ebp off though , but selecting gear and driving off gently did the trick , so it's now drivable , can't switch the brake on and there's the warning symbol lit , but it's progress Don't know anyone local with vcds so I'll try star performance down the road this week , he comes highly recomended , I need the suspension looked at as well , but a mate offered me the use of an athos console , so I might see what that's about , I need to start learning if I'm going to keep this thing Mike |
I had same problem and when i pulled the unit apart there was all sorts of nasty electrolysis between the connector pins on the pcb, i have a feeling if left it wouldn't be long before the board would fail.
Del ![]() |
Yup it all looked clean , there was signs of corrosion on the alloy chassis that carries all the MMI switches , so seems not the first time this has been wet
Mike |
Mine looked ok until i removed the pcb from the housing, then it had black goo around the pcb at the power connections, scrubbed it with soap and water with a tooth brush then dried over night and all was good again.
Del ![]() |
Okay so the MMI for the air suspension settings stopped functioning
So I reasoned I'd take the center console to bits again , stripped it and cleaned it again and re assembled it , no change , but the multi pin connectors seemed a bit rubbish , not positive enough , so a bit of wiggling and bingo , fortified by this I tried the parking brake switch ,so now it will switch off , and on , then the warning lights dissapeared , happy daze On the back of this the suspension has sorted it's self out , I realise I haven't fixed it , but it all works properly now So off to star performance in the morning , not sure what in going to get them to do , vagcom fault read for starters I guess Mike |
