Old 26th February 2017, 03:54 PM
Mine looked ok until i removed the pcb from the housing, then it had black goo around the pcb at the power connections, scrubbed it with soap and water with a tooth brush then dried over night and all was good again.
Old 3rd March 2017, 06:45 PM
Mikee Mikee is offline
Okay so the MMI for the air suspension settings stopped functioning
So I reasoned I'd take the center console to bits again , stripped it and cleaned it again and re assembled it , no change , but the multi pin connectors seemed a bit rubbish , not positive enough , so a bit of wiggling and bingo , fortified by this I tried the parking brake switch ,so now it will switch off , and on , then the warning lights dissapeared , happy daze
On the back of this the suspension has sorted it's self out , I realise I haven't fixed it , but it all works properly now
So off to star performance in the morning , not sure what in going to get them to do , vagcom fault read for starters I guess
Mike
