That's confusing neither of those are on the list.
That's what confused me I thought they gave me the rear diff code! I've still not worked it out, I was just checking what others I could use and the internet keeps saying 3.73 final drive for a s8. I thought it was 4.11
And 1st 3.57 2nd 2.2 3rd 1.50 4th 1.00 5 th 0.80 And now I can't find it?
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
That's because they are both FWD gearboxes
FBG tiptronic:
FD 4.111 1st 3.571 2nd 2.200 3rd 1.505 4th 1.000 5th 0.804 DGV 6-speed manual FD 4.111 1st 3.500 2nd 1.889 3rd 1.320 4th 1.034 5th 0.857 6th 0.730 For ease of comparison, A6q FTL (2.5TDI 180hp) FD 3.889 1st 3.750 2nd 2.059 3rd 1.320 4th 0.933 5th 0.711 6th 0.561 The FL A8 4.2 is 3.73 final drive, 3.7 is 3.889, S8 is 4.111. Last edited by MikkiJayne; 23rd March 2017 at 09:22 PM. |
Thanks
My ebay Elsawin is full of holes. I actually found references both DQS and FRF gearboxes, but when I go into the actual repair manual the entire transmission section is missing. Maybe someone with a better copy of Elsawin can find out. Definitely the list I posted earlier does not cover all A6 01Es.
I could be wrong but at least the DQS transmission appears as an option when I select the A6 2.5 tdi quattro as the vehicle model so it does appear to be a 6 speed. Also found this site, if its accurate it appears to be a 6-speed but with wrong final drive. S8 is definitely 4.111 final, code EUU is 4.111. http://workshop-manuals.com/audi/a4_...nd_capacities/ Last edited by Goran; 23rd March 2017 at 10:27 PM. |
It does say front wheel drive at the top of the chart.
The B7 RS4 ratios seem to suit me top, isn't as overdriven as a tdi 6th but it's a little better than what I've got now. If it fits the same is it still the 01E family? Or is 01A that different
The B7 gearbox is an 0A3 and shares virtually nothing with the 01E apart from the shifter mechanism. I have a one from a 3.0TDI in the workshop, bought cheap out of curiosity. Its longer (so custom propshaft), the diff is offset differently (so custom driveshafts), it has no provision for mounts on the side (so custom mounting solution) and it has no speedo output as it comes from the ABS in those models (so GPS or some other custom solution). It would require a substantial amount of work to put in a D2 - possible, but just not worth it. You'd be better off building an 01E with custom ratios.
