Old 23rd March 2017, 09:16 PM
FBG tiptronic:
FD 4.111
1st 3.571
2nd 2.200
3rd 1.505
4th 1.000
5th 0.804
DGV 6-speed manual
FD 4.111
1st 3.500
2nd 1.889
3rd 1.320
4th 1.034
5th 0.857
6th 0.730
For ease of comparison, A6q FTL (2.5TDI 180hp)
FD 3.889
1st 3.750
2nd 2.059
3rd 1.320
4th 0.933
5th 0.711
6th 0.561
The FL A8 4.2 is 3.73 final drive, 3.7 is 3.889, S8 is 4.111.
Old 23rd March 2017, 09:22 PM
Thanks
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 23rd March 2017, 10:24 PM
My ebay Elsawin is full of holes. I actually found references both DQS and FRF gearboxes, but when I go into the actual repair manual the entire transmission section is missing. Maybe someone with a better copy of Elsawin can find out. Definitely the list I posted earlier does not cover all A6 01Es.
I could be wrong but at least the DQS transmission appears as an option when I select the A6 2.5 tdi quattro as the vehicle model so it does appear to be a 6 speed. Also found this site, if its accurate it appears to be a 6-speed but with wrong final drive.
S8 is definitely 4.111 final, code EUU is 4.111.
http://workshop-manuals.com/audi/a4_...nd_capacities/
Old 23rd March 2017, 10:46 PM
It does say front wheel drive at the top of the chart.
The B7 RS4 ratios seem to suit me top, isn't as overdriven as a tdi 6th but it's a little better than what I've got now. If it fits the same is it still the 01E family? Or is 01A that different
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 24th March 2017, 08:23 AM
The B7 gearbox is an 0A3 and shares virtually nothing with the 01E apart from the shifter mechanism. I have a one from a 3.0TDI in the workshop, bought cheap out of curiosity. Its longer (so custom propshaft), the diff is offset differently (so custom driveshafts), it has no provision for mounts on the side (so custom mounting solution) and it has no speedo output as it comes from the ABS in those models (so GPS or some other custom solution). It would require a substantial amount of work to put in a D2 - possible, but just not worth it. You'd be better off building an 01E with custom ratios.
Old 24th March 2017, 08:31 AM
Something like this might help with the propshaft:
http://audis4parts.com/audi-a6-tip-t...eshaft-spacer/
I'm not sure whether the 5HP19FLA and 5HP24A are the same length, but as that piece supposedly fits A6 and RS6 that implies they are, meaning the piece should work for us too. I'll measure a 5HP24A and an 01E over the weekend and see what the difference is
Old 24th March 2017, 08:50 AM
Yes I missed that bit. I was working under the assumption that 6-speed 01E was only available as 4wd, looks like I was wrong.
The B5 S4 guys over on audisrs have done a 01E to 0A3 swap. Or rather MRC did the swap for them. Apparently its a much smoother box. Had I read this before when I had my gearbox out for a clutch replacement I would have gone for such a swap. The only downside is the high 6th gear. I would prefer 0.56
http://audisrs.com/ftopic31541-0-asc-0.php
Great find
