Old 24th March 2017, 11:57 AM
Actually, I suppose if you don't have all the factory parts to fit an 01E it makes no difference which gearbox you use. You have to fabricate mounts and shafts either way so you might as well use the more modern 0A3. The 01E is cheaper to buy, but by the time you've cured the 1/2 synchro weakness its about even with an 0A3, and the 0A3s will mostly have less miles I would expect. The lack of a speedo output is easily solved once you've figured out all the rest of the swap.
Hmm...
The 0A3 I have has crazy high ratios:
FD 3.889
1st 3.667
2nd 2.050
3rd 1.276
4th 0.882
5th 0.659
6th 0.528!!
4th in this is the same as 5th in the DGV. 70mph in 6th is 1800rpm
I've attached a spreadsheet I made with a gear speed calculator for the various common options which may help visualise some of this
Old 24th March 2017, 01:13 PM
Nice spreadsheet
I'm liking the low rpm at 70mph with your 0A3
Forgive my ignorance, does the rear diff have to match the final drive of the gearbox or are they all interchangeable? Are all D2 diffs the same?
Luckily 3.889 rear diffs for D2 should be easily available.
Old 24th March 2017, 03:16 PM
Yes it does, otherwise the back wheels will try to turn at a different speed to the front ones and the Torsen will explode
D2 and C5 diffs are the same so loads of options. The heatsink from the RS6 diff will even fit if we're getting ambitious
Old 24th March 2017, 03:24 PM
Good to know. So the final drive gearing for the rear wheels happens in the gearbox+diff together, but for the front wheels its all inside the gearbox.
Old 24th March 2017, 03:48 PM
Yeah basically. The gearbox output shaft drives the outer case of the Torsen. The inner gears of the Torsen then drive two outputs - one front, and one rear. The front output goes through a set of gears to shift it sideways and reverse its direction, and then it goes forward to drive the front diff inside the gearbox casing. The rear output goes straight out of the back and hooks up to the propshaft and rear diff. Because both front and rear diffs are being driven at the same speed they both have exactly the same ratios, abeit packaged slightly differently
This diagram shows the concept well. Its of a DSG unit, but the principle is the same for all Audi AWD (longitudinal) gearboxes (manual or auto). The Torsen is shown in red on the bottom right.
For completeness, the A3 and TT transverse setups are completely different.
Oh, here is a rather odd mirror-image of the 5HP24A which shows it too:
Old 24th March 2017, 04:23 PM
Any clearer?
Old 24th March 2017, 07:56 PM
Thanks for that I'll look into it some more, especially the gearbox mounts,speedo, flywheel, clutch.
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 24th March 2017, 08:03 PM
Ah yes I see now it makes sense. I knew the output shafts to front and rear had to be the same speed that's why I was confused, the reduction gear for the front driveshafts is in the front just behind the driveshaft flange (I didnt know that), so an equivalent reduction gear is in the rear diff.
Old 25th March 2017, 06:18 PM
Mikkijayne thank's for the gear chart i thought my car did around
45 1st
65 2nd
100 3rd
150 4th
186 5th
and 3rd to 4th was to big a jump 50mph the biggest jump it didn't help that all the car data sites seem to have the wrong diff ratio.
now I'm looking through the gear charts to see if a s4 or rs4 box would be the best for me thanks for your help
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 25th March 2017, 09:34 PM
SilverS8 SilverS8 is offline
I just missed a DQT for sale, but same guy has an FST box he claims to be equal to the DQT. Anyone have any info on that?
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
