D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus |
A phone call to your local dealer would establish the cost if you can explain what you need done and why. Audi dealers generally dont like updating mmi unless there is something not working for whatever reason. I was happy to pay an hours labour as they had to order in the update sd card from Audi which I wasnt charged for.
Is it K0770 or K0900 or something else ??? I need to ask main dealer for Last edited by Lui; 16th December 2016 at 09:10 PM. |
K0770 upwards is all you need to sort the sim/bluetooth issue but you might be best to ask them for the latest version available. There may be futher improvements on later versions that I am not aware of.
Let us know how you get on. |
Also is the K0770 the latest update or if have read that there's a K0900 out there too which is best to go for ??? Regards lui |
This is from a 66 plate D4 I was loaned today. 0942 seems to be the latest, no idea what has changed.
Nav version and maps are separate updates I think ![]() |
Nav updates are seperate to mmi, if you use the google earth map function, the maps are pretty much up to date anyway.
I've just gone straight from HN+DAB_K0097 to HN+R_EU_AU_K0900 with a modified firmware pack that's Bose safe on my 2011 A8 (Without Bose might i add).
Mines the 3GP with the HDD, not sure if they all are on the D4 A8? I followed a great guide by congo on the A5OC forum It took 1h10m, 13 updates, no errors, and all works fine (i used a SanDisk Ultra SDXC Memory Card 32GB 80MB/s Class 10 UHS-I) Haven't plugged VCDS in yet, i'll pluck up the courage to do the MAP, then have a go at clearing any faults. Albert
2011 A8 Executive 3.0 TDI Quattro |
how do you get the google earth function ???
is it through the audi connect mmi is up to date but nav maps need updating |
It's a map type option in Nav but you need Audi Connect via an active sim in the slot between the SD card slots.
#30
i have the sim slot in my car
is the sim an audi only part or can you use any sim to get audi connect? |
