Old 3rd April 2017, 01:19 PM
Pin 17 of the 26 pin connector on the back of the RNS-D, Should be blue with a red stripe. I strongly suspect it will be labelled as such on the top of the RNS-D.
Many thanks Ian, I knew someone like you would have the answer off pat.
That pin is labelled RFLS which I now know stands for Rückfahrlichtschalter (reversing light switch). I was pretty sure there was such a connection but a look at the RNS-D and online didn't show anything definite.
The blue/red wire is very evident in the loom to that connector block. I'll attack that another day.
Meanwhile over lunch today I stripped out the trim above the battery, found the cables to the boot lid and tapped into the blue/red wire there for "future use" (probably a bit of testing before the final wireless install). I did test it to confirm it was the correct one.
A bonus of removing the trim was that I got good access to the collapsing grommet on that side and glued it back together. And sorted out some other bits that were a bit "irregular".
A downside was that the cable loom was wrapped in the most disgusting gooey certoflex mess I've ever encountered. White spirit sorted that out.
Old 3rd April 2017, 02:14 PM
Yes, it is a bit grim..... I'm still haunted from when I had to strip out an entire loom to get all the bits for the electric rear seat install. My fingers were a sticky black mess for days. Had no trouble picking stuff up though....
Old 3rd April 2017, 03:53 PM
I would still put the aerial wire at the top of the rear window and "hide it" by keeping it tight to the rubber at the top so that you cant see it in your reversing mirror view - I think that would be better than either a side window or the front where you would see it all the time
Old 3rd April 2017, 04:09 PM
I'll test them all and see what works, though the side window is visually much the worst.
The way the roof lining fits and overlaps the glass means that the windscreen may work well and still be completely hidden.
The rear window could potentially be the same but there's the complication of the heated rear window and embedded aerials.
Old 3rd April 2017, 03:49 PM
Can't be bothered to wait, worked out that this was the final bit of wiring to go behind the RNS so "set to" this afternoon.
All done, wired in new power source(s) for DVB-T and reversing camera input/relay and it's working fine (only camera at present); thanks Ian.
Just need to get the RNS fully back into place; that will need some very careful positioning of the cables as it slides in.
Then there's loads more work in the footwell to rig up the DVB-T tuner, fit the tuner/camera changeover relay (in the post!) and so on.
