Old 5th April 2017, 03:23 PM
though is missing the one you REALLY need for an RNS, RGB. That's what the separate converter box does.
That's half of it.
The other half is the converter box should be injecting its presence onto canbus so that the RNS-D actually knows that there is a possible RGB input to switch to - Prior to you installing that box, you presumably couldn't even select TV as it knew you didn't have one connected.....
For this reason, simply hooking up RGB to back doesn't work. Many have tried and failed.....
Old 5th April 2017, 10:40 PM
Indeed as soon as the box is connected and powered up you can select TV, but I think the detection is actually pretty simple.
The 10-pin DIN connector on the back of the RNS is all that is needed and the contacts on that break down pretty simply into stereo audio (plus ground), red/green/blue (plus ground and sync) and two signal wires.
Those two separate signals are PAL/NTSC and Video-on. I haven't bothered measuring them, but I'd guess they are simple 5V or 12V vs 0V presence/absence, nothing cleverer.
Interestingly the TV tuner is PAL (of course) but the reversing camera comes up (brief initial display) as NTSC. I'm not sure if that initialisation display coming from the RNS or the converter box though.
How the RNS communicates with the OEM tuner, e.g. to change channel, I have no idea, but I don't think it's down that connector, it's purely for input.
Old 7th April 2017, 09:25 AM
A clue to that may be that there are some relevant coding options in the RNS (and cluster) accessible using VCDS. But they don't make any difference, the video display works without them if the signal is detected!
I guess the tuner commands go down the canbus.
Module 37 (Nav) channel 7. TV tuner is value 4.
Module 17 (Instruments) channel 140. This will normally be correct unless you've update from radio to navigation. (1=radio, 2=phone, 4=nav, 8=telematics)
Old 7th April 2017, 12:44 PM
I think more specifically, its the button presses that go down the canbus, that the TV tuner interprets as up/down channel etc....
Kufatec had an aftermarket media box for a while that plugged into the RNS-D and it was seamless, using the existing controls to do all sorts of wizardry with digital TV, dvd players etc.
They are both on the bosch infotainment canbus (i.e. both on the same side of the TMC/Can gateway) so its all proprietary signals that the rest of the car won't see or care about....
The cluster can't see the bosch canbus directly, it only sees the converted output the other side of the gateway, which would possibly be used for a MFSW or remote audio controls in the rear armrest on the LWB.
Old 7th April 2017, 01:27 PM
Still do I think. This is what you need:
https://www.kufatec.co.uk/shop/en/im...a-adapter-plus
and:
https://www.kufatec.co.uk/shop/en/im...sic-basic-plus
That's £218 in total but looks intriguing. Still available.
Given there's no auto-switching of a reversing camera with RNS-D (Kufatec says so) and you need one of a specific group of (expensive) controllable DVB-T tuners it's not relevant to me.
I might even manage an element of auto-switching; if I'm listening to digital radio (or tuned to TV) via the DVB-T my completed install will turn on the reversing camera automatically whilst keeping the sound from the DVB-T tuner.
