Old 12th April 2017, 12:39 PM
chrisc201 chrisc201 is offline
Ah ok, I'll see if the scan sheds any further light and report back.....on the aux inputs point, I was under the illusion the as l was rca input to the tv tuner that you then had the option of selecting via aux 1 and aux 2 on the mmi?
At the moment, when I select CD/TV it is only CD that actually comes up, no option to change source to tv or aux.
Thanks again,
Chris
Old 12th April 2017, 12:54 PM
The AUX1 and AUX2 inputs are connected to the TV. So once the TV is back in the MOST loop you enable AUX1 and 2 from the setup or green menu (not sure which menu) then they, and TV, will be selectable from that button
The inputs you add to the red connector will look like this...
http://forum.a8parts.co.uk/showpost....8&postcount=25
Matt
