Old 15th April 2017, 10:14 AM
Sitting at my local delivery office ready for delivery, which means Tuesday at best.
No, it arrived!
Same as the previous unit except there's an extra wire in the power connector.
Reading the "Chinglish" manual (both are the same) again this appears to be something to do with automatically switching the picture to an A/V input from a reversing camera.
I might have a play with that and see if it provides a simpler solution than my current one which uses a separate relay.
Old 17th April 2017, 10:48 AM
The new unit works fine and has much better reception than the old one, so whatever fault that has appears to have wider consequences than just losing video sync.
Though the now revealed/understood reversing camera input will not be used, as noted in the relevant thread, as it loses the TV/Radio sound unlike my relay solution.
To do the initial tuner setup I ran an aerial cable out to the car from the house distribution amplifier, makes sure it's got a comprehensive list of channels.
