Old 16th April 2017, 09:13 PM
On a slightly related note, I discovered today that if you hold down the boot lid button on the key, whilst the lid is on its way up, it will go back down again.
I'll get my coat.
Old 17th April 2017, 07:49 AM
Yep, I have that as well.
Mine also opens when I'm putting my keys in a pocket, but I think that is a finger problem.
Could you pass me my coat while your there?
Old 1st June 2018, 11:52 AM
homer simpson's Avatar
Did anyone ever gas their struts? Mine seems to close OK but will not lift up when the button is pressed. I'm assuming it's the struts and not the motor?
Old 1st June 2018, 05:07 PM
I retrofitted mine and it struggled to open the first few inches and would shut back down unless helped manually. I found on a US forum that adusting the bolts in the corners would help it pop up - they are on the hinge brackes out on their own and the heads are under plastic caps. When unscrewed they seem to press on part of the hinge and do incerase the pop-up but it does't look like that is what they are meant to be for.
There are the Audi parts...
12 4E0 827 551 A gas filled strut 2 PR-4E2,4E4 manual
(12) 4E0 827 551 C gas filled strut left 1 PR-4E7,4E9 power
(12) 4E0 827 552 C gas filled strut right 1 PR-4E7,4E9 power
I have the 551A at the moment but will be getting the 551C 552C equivalents from SGS, they are about £38 with postage.
I have contacted SGS, about the difference, it seems the more powerful one is 390Newtons at the top which might make it hard to close?
I'm not sure which to go for...
"Thanks for your enquiry.
GSC2546 is the strut recommended for replacement at 265N.
Both struts are equal in length but the GSC2861 has more force at the very top 390N.
It will not make it pop at the bottom any faster, once the strut is nearly at the top will be the most force.
New gas struts are available at a cost of £38.74 for the pair delivered (£13.49 per strut plus £5.30carriage and VAT), are covered by a two-year guarantee and are available on next day delivery to mainland UK.
If you would like to place an order or have any questions please give us a call on 01332 576 850
Kind regards,
Nick
SGS Engineering"
Old 1st June 2018, 08:50 PM
Interesting. The Audi ones are showing @ £38 each so half price from SGS. Your question about the higher 390N strut is a good one and I hope someone can answer it to help me decide too
Old 1st June 2018, 09:16 PM
I have ordered GSC2546 so will post back with the results in a week or so. It's a shame these will be black and the Audi ones stainless finish but hey ho.
Old 1st June 2018, 11:21 PM
H-M3 H-M3 is offline
Perhaps you should’ve mentioned a group buy Snap as I think loads are after them??
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
