So my handbrake has 4 clicks (and more if you want it to hold the car in place) and shoddy judder under braking at motorway speeds.
My assumption was that it was always a faulty adjuster on the rear calliper. When you would lift off the brakes gently from a standstill, you could hear the fronts dis-engage at different times, reinforcing the idea that an adjuster was away, and the brake balance was off - something I have dealt with on multiple old Audi's. So the rear (drivers side) calliper off and the attached shows it's sorry state. ![]() And the front brake had far heavier worn pads than the other side, and of course there's a warped disk somewhere in amongst it all. (Assuming that the D2's are the same opposing 2 circuit brake setup as all old Audi's) then it all adds up. New pads, skimmed disks are the future for me. The rear callipers are en-route to Bigg Red to make them wonderful again. Could fix them myself for a fraction of the price, but getting them done properly will mean another 100k without worrying about them. Figured I'd post a wee bit about this if it helps anyone else. Simple fundamental stuff for most mechanics, but for the guy keen with a spanner wanting to make sure their own motor is kept in top condition, this stuff can be handy! |
Bigg Red did a great job on my rear calipers
![]() Personnaly, I dont buy the thing about warped discs. I found the article by StopTech "Warped discs and Other myths" convincing and after experiencing long term issues of brake judder myself remain convinced that the source is normally brake imbalance (in my case from sticking front pads and rear caliper issues the same as yours) which can be exacerbated by worn control arms. I have just had the front calipers refurbed by Addiction motorsport (recommended by bigg Red as the latter dont refurb Brembos) and with new Brembo pads, new Ferodo discs I now have no shudder at all. The new discs were required as the sticking pads had badly ridged the disc. http://stoptech.com/technical-suppor...nd-other-myths
I have seen that article before but the movement of the steering even at low speed and the uneven wear on the pads leads me to believe it is a wrapped disk. Not sure those disks will make it back on the car mind you. Trying to source a couple of replacement front disks for reasonable money.
The rear disks made me laugh, turns out they are the same as A4 fronts ![]() |
The only drilled ones I could find didn't look particularly legit... I will have to dig harder over the holiday weekend. Will verify the originals are warped with a gauge first. Know someone who has one and rather handily have spacers that I can use to hold the disks in place on the hubs while I check :-)
Got these back from Bigg Red a few years back for my Cabrio (same setup as S2), they have been spot-on ever since, they work perfectly, and still look fresh after doing both the NC500 and a tour of Europe. Was impressed with their work, worth the money.
Have arranged to get the S8's done in black to match the Brembo's. ![]() |
And of course the disks on the front of my cabrio are smaller than the disks on the rear of the S8
![]() ![]() Last edited by B4-Andy; 27th April 2017 at 10:56 PM. |
The first time I saw a D2 S8 was in a dealership when I was buying parts for my Corrado. It was an FE in Avus with purple leather, which was enough in itself, but when I saw the rear brakes were bigger than the Corrado's fronts I was smitten
![]() I have a problem with pad pickup causing an intermittent wobble on mine too, and vexingly I can't burn it off no matter how much I try so I'm going to have to replace discs and pads fairly soon too. How many people would be interested in drilled / grooved discs for the FE? MTec do some good options but not for the FE. They might consider it if a bunch of us were interested ![]() |
![]() I am always paranoid about front disks, currently scouring the far flung corners of the web trying to source 2 Brembo disks, but it's not looking hopeful. Someone in Italy seems to have some but want too much cash. Might have to look at alternatives. |
