Old 12th May 2017, 07:21 PM
It is a noticable change as I noted a couple of years back. But I would like to know exactly what it does. Does it just change the gear shift points in Drive or does it also change the Sport settings?( I cant really detect any difference in Sport). Does it change fuel/air settings or is it confined to gearbox setup?
Old 15th May 2017, 09:07 AM
pete-p's Avatar
pete-p pete-p is offline
I've been thinking of doing this with mine soon, I've noticed that when the wife is driving (mostly around town), it seems to use more fuel. I think it's because it's holding 3rd until nearly 35mph and not changing to 4th (whereas I usually drive in tip mode).
Having looked at the link in the OP www.audipages.com it looks like the xxx1x is de-activating the dynamic shift program (DSP).
There is a line that says "The dynamic index number controls how the transmission shifts. If your A8 has the stock transmission coding of 00002, then it sums dynamic index number closer to "old man mode" versus "sport mode"." So it also looks like the xxx1x is activating the "Sport Mode" which surely should be activated in an S8 by default?
Cars...
Old 15th May 2017, 09:11 AM
Adding in that extra 1 at 00X1X made rather subtle changes for me.
It seemed to be more responsive to change of driving style though that's difficult to measure.
It DEFINITELY would change up to higher gears when driven gently or on cruise control at local road speeds whereas before it was often stuck needlessly at higher revs when "pottering".
The latter behaviour was noticeable and made "wafting along" feel better too.
