Old 18th May 2017, 10:29 AM
bobbyshafto bobbyshafto is offline
Default Parts List
Hi,
I have an initial list of bits I'd like to sort and thought I would see if anyone had any of the following available:
1. The Two buttons in the drivers door 'shut' (?) - Boot Release and Alarm Deactivation I think
2. Wood (Vavona ?) Trim for top of handbrake
3. Drivers Footrest - carpet is cream in colour
4. In the boot, to the bottom (nearest lights) right hand corner is a rectangular piece of trim that creates a sort of 'pocket' to hold items in one place, about 10 inches by 4 inches, and the four lugs have broken so it just falls out!
Many Thanks
Neil
Old 18th May 2017, 10:33 AM
I have one of those. Tiny hairline crack in the top lacquer surface that is invisible unless you look very very closely.
Edit, yes just checked, 4D0 864 375 F, VAVONA. Hairline crack across the lacquer about 30mm from the front and immediately above the front mount/clip which is unbroken and has the standard extra duct tape to make it fit better.
Are you going to the annual meet?
I did have a spare boot side panel but sold it a while back, you might want to look for a full height one or just fix the one you have by using short screws instead of the lugs.
Floor mats you'll probably have to buy new, they wear out.
Buttons - try our sponsors they should have loads!
Old 18th May 2017, 11:20 AM
Default Marvelous!
HPSauce! Marvelous, thank you - how much do you want for the Handbrake Trim, inc. postage, and do you 'PayPal'? (I'm not about for the Annual Meet as I am moving my 82 year old mother!!!!!)
Many Thanks
Neil
Old 18th May 2017, 11:45 AM
Hi Neil, I'll PM you and send some pictures but check/recheck your colour coding first. Yes I do PayPal.
It will need careful packing, probably in a rigid tube, so not sure on postage and price yet.
Do you need any other Vavona trims, I have a fair selection apart from those around the door switches?
Old 18th May 2017, 01:25 PM
Just realised you said footrest not carpet. Our sponsors of course should have one, but some people have replaced them with Phaeton-style footrests.
See here for example: http://forum.a8parts.co.uk/showthread.php?t=8957
Remembered I saw the dodgy footrest in one of your photos! You could of course just take it out and cover it with whatever surface you wanted easily enough.
Attached are pictures of my handbrake trim. The surface finish crack could probably be made to vanish with polish or nail varnish. I suspect it's a common problem as it's where it gets squeezed between the handbrake and armrest, so in fact is out of sight anyway.
ID:	16091   Click image for larger version
ID:	16092   Click image for larger version
