Old 20th May 2017, 09:11 PM
Prefferle Prefferle is offline
Well, I removed all the left sides, armored vehicles, LWB and 2007> and we are left with ...
(1) 4E0839016 door lock with door contact switch, F >> 4E-7-010 181* right ;;1 PR-GZ0
(1A) 4E0839016A door lock with door contact switch, F >> 4E-7-010 181* right ;;1 PR-GZ2+K8B
If you look at your PR codes, it is GZ2+ K8B = 4E0839016A
PRCode: GZ2 = Door power latching seems to be the clincher - do you have soft close?
Hi - Yes only discovered today that soft-close actuators are fitted to the car(!!), I don't think the previous owner knew this either... - this feature never worked in my few weeks of ownership. Didn't know it was there. p
lease see my other post regarding the soft close for more detail.
I only discovered this feature as I had removed the door card today to see what door lock P# I had fitted - didn't get far after discovering soft close feature fitted (then the rain started).
Any ideas on why none of the soft close doors arnt working? what should I check?
The Rear Right door never locked at all with the key fob or central locking. do you think the door lock could be issue?
Any guidance greatly appreciated.\\Cheers,
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
