Old 19th June 2010, 01:16 PM
Mr K Mr K is offline
Default RNS-D Safe
I have a spare Navi Plus RNS-D from a D2 A8 unit that i have managed to lock - bassically when you turn it on it comes up with SAFE - does anyone know how to get this back to the point of entering the code? I bought it for my old B5 A4 (Its not nicked - i do have the code for it) but with the car sold i want to test it before i sell the unit.
Old 19th June 2010, 01:34 PM
darrenjoe90's Avatar
just leave it turned on for an hour and it should then allow you to enter the code.
Audi S8 Phantom Black
Old 1st August 2010, 07:09 PM
Mick Mick is offline
The RNS-D requires another 12v feed that isnt present on non sat nav cars.
If you look on the RNS there should be a wiring diagram showing which is the safe wire.
The SAFE displayed on the screen is not related to the lock code but without it connected you cannot enter the code.
Old 1st August 2010, 08:56 PM
^^^ Wot he said..... Often seen if you try and run one on a bench PSU out of the car....
Put + 12 to the permanent live, ignition live and safe and you'll then be able to enter the code
Old 6th August 2010, 11:55 AM
Yup - i found that out after playing around with it in my old A4 which had a Symphony double din unit in it.
When i plug it into my S8 (equipped with a RNS-D and TV tuner) i still get safe. I am yet to try leaving it plugged in for an hour.
