Old 25th May 2017, 01:17 PM
I noticed something similar after finding my battery flat fairly recently. All OK now without any intervention but took a few days to resync.
Old 25th May 2017, 04:49 PM
I never lost a mast symbol in all these years. Not a single time.
Car is regularly on the road though.
If cluster was without power it may have lost one hour shift between Germany and UK, which is very easy to correct as soon as mast symbol returns.
Old 25th May 2017, 05:01 PM
Follow Sergey's instructions for resetting the clock by pulling the instrument cluster fuse and it should then re-sync fairly quickly after leaving it parked up for a couple of hours.
I had odd behaviour from mine once, after it was left parked in the garage for several weeks, and this was the only way to resolve.
Old 5th July 2017, 08:10 PM
RS6's Avatar
RS6 RS6 is offline
would anyone be up for fitting one to mine
no clue what im doing... in these matters
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 6th July 2017, 02:32 PM
The_Laird The_Laird is online now
My mast symbol eventually returned after a week or two, but no amount of fuse pulling and 'tricking' the clock would force it. Like when I first installed it, I just had to let it find the signal on its own. Interestingly, on both occasions, it took much more than the 3 days that Sergey's write suggests is when it should 'forget' that it's there.
RS6 - I'd be happy to help fit one if you're not far from NG13 post code (but I've not fitted the receiver to the spot where Sergey's is - that's a bit trickier, although I have heard that ther's a 'short cut' to pulling out all the back of the dash!
Old 6th July 2017, 02:57 PM
Mine, as mentioned earlier, is behind the dash to the left of the steering column, immediately above the removable knee panel; works fine. Held by blu-tak!
To fit it there you "only" have to remove the knee panel and the socket on the back of the instruments is accessible from behind.
That "should" just involve unclipping the small trim below the steering column and undoing a few (5?) screws/bolts to remove the knee panel.
PS James (RS6) is down in Fareham, nowhere near you Jim.
Old 6th July 2017, 09:30 PM
RS6's Avatar
RS6 RS6 is offline
That is very good of you sir true gent
May take you up on the offer don't mind traveling
HP make it sound easy as well
Old 6th July 2017, 10:29 PM
I'm a lot nearer than Jim, but others may be closer.
Do you have the unit yet?
Old 8th July 2017, 10:17 PM
RS6's Avatar
RS6 RS6 is offline
Not picked one up yet andrew on the to do list
was hoping someone whos already done it could help me out
Old 11th July 2017, 01:52 PM
One of these modules on Ebay if anyone's looking for one.
It's the later, rarer module too with the 'A' part # suffix.
http://www.ebay.co.uk/itm/263083317896
