Old 14th June 2017, 08:26 AM
D2 Noob D2 Noob is offline
When it works it's fine although you can hear a quiet scraping sound. But it only works when it feels like it. It can work for 2 or 3 days then nothing or as it did the other day went down and didn't go back up until several hours later
Old 14th June 2017, 08:49 AM
Sounds like more than just a lube problem if its scraping. You may need to remove the door card and door subframe to get it sorted. There's good guidance in the tech docs on this forum.
Old 14th June 2017, 05:14 PM
Ok thanks. I was guessing that would be the case but hoping it wasn't
