Old 16th June 2017, 03:22 PM
Turbo Tony's Avatar
Joining traffic sideways sounds spectacular!
So, what did you decide? You were buying today weren't you?
Storytellers Villa Orlando
2008 Audi S8
Old 16th June 2017, 03:38 PM
Sideways is spectacular, but when you floor it in wet and ESP kicks in before you even get up to speed, your engine is reving, exhaust is screaming but car is literally crawling isn't - rather pathetic, but the back end doesn't steps out
Well, I was going to buy it today, but as there is no difference between today and monday due to the weekend, I thought I will take couple more days to decide, but it looks like Goodyear Eagle's F1 Assy 2.
Old 16th June 2017, 04:43 PM
Lee S Lee S is offline
Interesting. I would love to know your opinions and thoughts on the GYs compared to the P Zeros. Thanks.
Lee
2017 Nissan Leaf Tekna
Old 16th June 2017, 05:38 PM
Same here Lee.
Although it may take a while as it needs 500 miles to bed them in, and usually it takes me a month if not more to cover that distance, but as I love night drives with ''no destination'', it may take less time before I can start throwing it around the corners
Old 16th June 2017, 07:13 PM
I know exactly what you mean. Thankfully my S8 is old enough not to have ESP or traction control and with mechanical throttle so I do not get any interference but it does catch me out sometimes. While I expect rear wheels to spin in wet sometimes it throws me unexpected surprise in dry. I bet it looks a bit wonky if I get scared and release throttle. By comparison my other car 2.5 TDI A6 quattro looses traction at he back a lot more as it's tuned to have around 440-445Nm compared to S8 410Nm and has manual gearbox and skinny tyres. Although I am pretty good after 5 years of A6 ownership to judge grip sometimes it catches me out and when ESP cuts power it seems to last forever. I would expect D3 and S car to have faster and more sport orientated ESP to be less intrusive.
Also on A6 if I switch off ESP it still seems to be working but at lesser stage, only way to fully disangage it seems to be cut power yo ABS ECU.
Old 16th June 2017, 07:22 PM
I never knew that ESP was that recent (OK 20 years), my 1998 PF S8 had it and it worked really well, only when you pushed to (or beyond!) the limit.
Old 16th June 2017, 08:26 PM
We are drifting away a bit here from the thread but yes mine is a very early S8 from 1997.
Old 8th July 2017, 06:11 PM
Just to follow this up GoodYear F1 on my S8 seem to be OK in hot weather, really nice grip and full tank of petrol means more weight at the back eliminating rear loosing traction. But they have worn quite a bit as well. Thry have probably gone from 7mm tread to 4mm tread in less than 4k miles and have been awful in cold and wet.
Old 9th July 2017, 10:17 AM
Yes, my friend said the same thing when I suggested to him I was going to buy a set of F1s. He said that despite the 'hype' they were very 'ordinary' and they wore out completely in about 8k to 10k. I canned the idea and got a set of 4 P-Zeros with PNCS from Oponeo. I'll stick with what works the best on my car. I have never ever had a loss of traction or any breakaways no matter what the conditions, they wear well and fairly evenly. I always buy the 'R01' specced versions too. If they're OK for an RS6 they'll do me !! Fine tyres.
Lee
Old 22nd July 2017, 06:34 PM
So, what did you go for in the end and how have they worked in practice?
