Old 19th June 2017, 03:01 PM
How did that come loose???
Trying to remove them can be a pain when you intend to so how has this happened on its own?? Mystery.
¯\_(ツ)_/¯ mystery to me also! Maybe I should get her lifted again and inspect the centre support bearing as that's above the shield.
Matt
Old 19th June 2017, 08:09 PM
Joe2.0E Joe2.0E is offline
Heat shields are generally fixed with a pretty poor type of rivet that are prone to failure. Heat shields are quite cheap but fitting will involve serious labour for access, might best left alone for now.
Old 19th June 2017, 09:15 PM
Turbo Tony's Avatar
One of my Heat shields had worked itself loose too. It hadn't started rattling or anything, but the fastener wasn't holding it in place anymore. It's getting changed as a precaution while they fit the OEM exhaust.
I'd have a good snoop around the affected area, just in case something else caused it. If there's nothing immediately apparent, replace it and forget it.
Storytellers Villa Orlando
2008 Audi S8
