Old 21st June 2017, 06:43 PM
I remember there was a simple check to test it, if you can stop it with a pen then the clutch hasnt engaged.
And if it takes your hand off it's working
Couldn't you test it just as easily (but perhaps a little more safely) without the engine running? If the engine/coupling is hot, I would imagine the fan should be difficult to turn, should it not?
