Old 2nd July 2017, 09:38 PM
Lee S Lee S is offline
Hi Joe. Sorry, yes. Updated OP with new bullet points. 78k. Agree. Need to get someone to look at it before something goes pop. Its not looking very promising if the noise goes completely when in neutral is it? Surely that means all of the drive-train (diffs, CVs, transfer box, prop shaft, wheel bearings, etc) is all still moving and all I have done is remove the gearbox/TC from the equation?
Lee
2017 Nissan Leaf Tekna
Old 2nd July 2017, 09:51 PM
On a deceleration run the and gearbox in normal operation it would allow some degree of engine braking by delivering torque to the engine would it not?
If my understanding stands true then extra load would be applied to all the other components as against to a in neutral test.
Old 2nd July 2017, 10:04 PM
Turbo Tony's Avatar
When it stops at around 10 mph, check your driver info display to see if that matches the time the gearbox is shifting down to 1st.
Storytellers Villa Orlando
2008 Audi S8
Old 2nd July 2017, 10:27 PM
Very good point Del, yes you're correct, so it could still be something like a dodgy CV joint (he says hopefully...)
Lee
Old 2nd July 2017, 10:32 PM
I will check that Tony, yes, but I think it doesn't shift down to 1st until really low, like 5 mph or something, maybe even lower. I will try it tomorrow to see. I have done about 180 miles in it over the weekend and to be honest it doesn't seem to be getting any worse. Looking back, it seemed to have started around the time of that really really hot weather, when it was about 28-30 degrees for a couple of days. Maybe coincidental. It's just been in for a longlife service and a couple of other odd jobs to Audi and they didn't comment, so we will see. Thanks all.
Lee
Old 3rd July 2017, 07:58 PM
It's still in 3rd (sometimes 2nd) when slowing down to 10 mph and only really drops into 1st if speed is like 2 or 3 mph or I stop. So 10 mph is not really related to a specific gear.
Lee
Old 4th August 2017, 11:47 AM
The behaviour sounds like the prop centre bearing, but the mileage is very low for that to be happening.
Old 4th August 2017, 08:17 PM
Pug Pug is offline
Did you ever get to the bottom of it?
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
