Old 4th July 2017, 01:55 PM
Resolutionary Resolutionary is offline
Update! At the weekend I pulled the leads to check for ingress under the cam covers. The verdict - not good.
There was a significant amount of oil in all 6 spark plug holes. I strongly suspect my running issues may be in part due to this, which would not be too bad I suppose (better than a faulty transmission!).
The car is going to Tuning Werkes tonight for open-heart surgery tomorrow, namely:
- replace cam cover gaskets (both banks)
- check coilpacks and spark plugs, drain replace as necessary
- check crank-case breather pipe
- rectify headlight levelling issue (warning light driving me mad)
- check rear suspension and exhaust mounts (clunk / rattle over bumps)
- flush and replace engine oil
- flush and replace gearbox oil if necessary
- flush and replace coolant
Fingers crossed after all this work, the car responds well and is good as it should be. I'll be back!
Recently converted Avant enthusiast!
2002 Audi A8 2.8 Quattro Sport - the gentleman's cruiser
