Old 24th July 2017, 05:06 PM
Default Tyre sizes
A quick question....
Whilst searching last week for new tyres using the 'insert your reg' function many online retailer use, they all informed me my car was 265/35/20.
However whilst reviewing an Audi tech doc last night I noticed Audi published the figures 275/35/20.
How so? And does that mean the rims would actually take a wider tyre......?
Old 24th July 2017, 07:08 PM
Turbo Tony's Avatar
I found the same thing. My car runs the 275 width, although the fuel flap lists the 265 size. They were fitted by the previous owner, so I can't compare with the 265 size.
There's more choice in that size and fractionally more rubber too, which should make for a slightly more comfortable ride.
Storytellers Villa Orlando
2008 Audi S8
Old 24th July 2017, 07:30 PM
kele kele is offline
I found I rubbed the front inner wings with the 275 profile on mine. So I switched back to 265's
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 24th July 2017, 08:06 PM
Markr Markr is offline
If you change tyre sizes, check with insurer, as some deem it a notifiable modification.
Old 25th July 2017, 01:37 PM
Looking at your picture, you seem to have the wheels with part number 4E0 601 025 BD.
This wheel has an ETR of 45 and is 9J x 20H. In the Audi Wheel and Tyre Guide, there are 6 '9J x20H' wheels; 4 have ETR of 46 and 2 have ETR of 45. [ETR is the hub offset].
Audi tyre sizes for them are:
9J x 20H - ETR 46 - 275/35 R20
9J x 20H - ETR 45 - 265/35 R20
Presumably to allow for prevention of 'rub against the arch' for the ETR 45s
Julian
Old 27th July 2017, 04:13 AM
roberto's Avatar
roberto roberto is offline
275-35-20 will be fine i use these with ET35 wheels
its only about 7mm difference in height
and 10mm width
and they look better, 265's always looked a bit stretched for me
Plus the 275,s are cheaper
win win
Old 30th July 2017, 09:39 PM
You can check this easily compared to your current wheels - just put the two sizes into http://www.willtheyfit.com and then see how much additional poke on the tyres there is plus any difference in total diameter etc. Then compare the differences stated against where your current tyres are . . . . And voila!
Old 15th September 2017, 04:36 PM
1781cc 1781cc is offline
Just to add to this for anyone else...
I just fitted 275/35/20 and they are perfectly fine, attached is a pic of the difference between 265 and 275 running 35 on 20s
ID:	17032   Click image for larger version
