Old 25th July 2017, 04:59 PM
You could try squashing the pins (very slightly) too to make them a tighter fit. Had a similar problem with my washer motor recently. The connector seemed fine and it worked again when I dismantled half of the car to get to it. Put everything back and the damn thing stopped working again. After stripping the car down again I found that wiggling the wires didn't affect it but pushing on the connector did. So I gave the pins a light squeeze with long-nose pliers and that seemed to fix it.
Failing that, it's probably a bad connection where the wires attach to the pins, as you suggested, but it should be possible to determine if it is that by wiggling/pushing/pulling them.
