Old 26th July 2017, 12:52 PM
How are the mintex coping on yours?
I have used them in the past on other cars and they were fine but these are still in my ebay shopping basket. Mintex, Pagid and Textar are all part of Nisshinbo so I assume they are the same. I used Pagid from Eurocarparts on the rear and they were coated with the zinc anti-corrosion coating.
I am not sure if the Mintex have the coating and I would prefer ones that have this.
Old 26th July 2017, 05:34 PM
H-M3 H-M3 is offline
Zimmerman are good too as they come coated. My friend Marcin recommended them.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 26th July 2017, 06:13 PM
Joe2.0E Joe2.0E is offline
Would skimming the discs be an option to remove the lip ?
I've never had it done but I saw a garage recently advertising "insitu disc skimming.
I have also had some eyewatering quotes over the years for pads/discs too from my local Dealer on a D3 & D4. Ask for the part no.s to be put on the estimate and a few minutes on eBay will tell you what's what.
Discs don't seem to last like they used to.
Old 26th July 2017, 07:38 PM
Pug Pug is offline
Skimming the lip off the discs is plausible. I'd ask Audi for the measured thickness against the minimum allowable thickness to see how deep the lip is. If it's got plenty of 'meat' left, you could skim them. Generally an hours labour per axle.
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 9th August 2017, 11:34 AM
goldsax goldsax is offline
update:
front pads, rear pads, rear disk, all pagid branded. fitted by a local garage that had the equipment to relax rear calipers to wind them in. they said it was a 1.5 hour job
cost :
£230 parts/labour/vat included !!!!!
how can an Audi indie quote £750+ and a dealership even more.
thanks all for informing me how to read the relevent bits on the buildsheet.
cheers raj
Audi A8 2011 3.0TDI
Old 9th August 2017, 02:29 PM
Are you sure they were Pajid? Very cheap man!
Old 10th August 2017, 07:31 AM
i was going to order the parts myself: pagid parts come to £142 +£10 delivary.
but for my DB9 the rear pagid pads alone were £170 !!!
Audi A8 2011 3.0TDI
Old 11th August 2017, 12:19 AM
any links?
Old 11th August 2017, 08:25 AM
www.buycarparts.co.uk
Audi A8 2011 3.0TDI
