Old 4th August 2017, 04:00 PM
Thanks folks.
Do the wiper arms have nuts to hold them on or are they just a push fit on the splines?
Nuts to you. As Sergei says, you need to hold the wiper arm down so its parallel to the screen otherwise it springs up when the nut is removed and can damage ther bonnet edge. (It is easier to remove them with the bonnet shut)
Old 4th August 2017, 04:12 PM
Thanks again; I'll do this when I go delving into the air intake to test the fan/controller etc. and fit a new sponge seal around the edge.
Having the air intake cover off may also help refitting the trim panel. Certainly sounds (and feels) like there's something that needs to engage that was missed previously.
(And I'm used to the precautions you need when removing sprung wiper arms, I usually have some protective cloths around as well. )
Old 19th September 2017, 02:54 PM
Well I had this off today and found indisputable evidence of a bodge, probably by whoever replaced the windscreen years ago.
(Incidentally I removed the wiper arms with the bonnet open, blades removed and arms up at 90 degrees to make "wiggling" easier, there's just room)
The central fixing wasn't a fixing at all. The part of the trim that has a bolt through it was essentially not there, probably broken off and discarded in the past.
The trim was raised up because it was jammed against a useless bolt nut and washer, probably an attempt at a repair that achieved nothing.
I suspect originally there was a deepish recess in the trim with a bolt through it going into the same sort of clip still present for the two outer fixings.
The clip had gone and a rusty (non-Audi) bolt was through a large washer and the hole in the body bracket with just a nut on the other side! So not a proper fixing in any shape or form. I removed it, picture attached.
I've put the trim back but it's only secured by the two end bolts, though does now lie a bit flatter in the middle., but moving around more.
So now I need a replacement UNBROKEN trim piece (that incorporates the washer jets etc.) and the fixing bolt and clip.
This is what had been used to unsuccessfully bodge it!
Old 19th September 2017, 03:07 PM
From our sponsors: http://www.ebay.co.uk/itm/Audi-A8-D2...item28352e950e
Or new for about £180 if they're still available.
Old 19th September 2017, 03:28 PM
Already been on the phone to Maria and ordered that, plus the cover that goes in front of it on the drivers side (also damaged!). http://www.ebay.co.uk/itm/192292751197
Just over £40 the pair, delivered.
MJ, do you happen to know how the centre fixing works? Maria said she didn't have any but it's listed as using a M6x32 bolt and appears to go straight into the support bracket on her diagrams.
Is the bracket threaded or does it use a clip of some sort (speed clip?)?
Old 19th September 2017, 03:54 PM
The bracket should be threaded so the M6 bolt goes through the plastic trim and straight in to the bracket.
If its previously been bodged though it could be that the original bolt seized and the thread has been broken or drilled out. If so, an M6 speed nut such as N90168604 would do the job instead
Old 19th September 2017, 04:00 PM
Thanks.
The bolt I took out was very loose in the hole and looks about M6 size so I'll be prepared to deal with whatever I find.....
Old 19th September 2017, 04:05 PM
As MJ states, the bracket is threaded and (with luck) the M6 bolt with washer should just go straight in. The m6 bolt is overall 35mm in length (30mm threaded portion).
Old 27th September 2017, 02:15 PM
It's been drilled out big time, sizeable hole about 9mm wide!
And the plate is too big to fit a speed nut, it won't reach in far enough.
Any suggestions? This is what it looks like:
