Old 19th August 2017, 04:58 PM
adeneo adeneo is offline
It's a common problem, it's one of the stepper motors for the air vents, they click every 7 minutes when they're stuck or broken.
It should throw a fault in the system if you have it scanned, if I remember correctly there are about five little motors, VCDS should tell you which one is making the clicking sound, and that needs replacing.
The manual says
Replace the actuator motor if it makes clicking or rattling noises in regular intervals (approx. every 7 minutes).
These noises originate via activation of the actuator motor via the A/C control head -E87- in actuator motor drive.
Activation occurs to maintain the flap/motor securely in one position.
Old 19th August 2017, 05:33 PM
A8essex A8essex is offline
Re - Would it be this http://forum.a8parts.co.uk/showthread.php?t=1624
Thanks for that...So happens a mate had one of those relays in his garage so after a bit of fiddling we have just swapped the one highlighted in the picture as the "most common cause" . Same issue, so either a) its not that relay or b) the relay we put in is also faulty !
Does the VAGCOM thing tell you which relay it is...and if so, how do you then know which relay is which ?
Old 19th August 2017, 05:34 PM
Sorry...i wrote relay....and meant motor....we swapped that little black thing circled in the pic !!
Old 19th August 2017, 05:44 PM
Yes, those are stepper motors / servos.
As I wrote, there are several of those that can break.
VCDS will give an error like ...
Left Footwell Flap Positioning Motor (V108)
or
Rear Footwell Vent Positioning Motor (V112)
...that should tell you what motor is causing the issue.
The manual has a description of each motor, how you get it to etc. Some are harder to get to than others.
Old 19th August 2017, 06:23 PM
Cheers Adeneo...is the "manual" you refer to something that is publicly available ?
Old 19th August 2017, 06:28 PM
It probably is, someplace, otherwise Bentley Publishers sells it.
Old 19th August 2017, 06:51 PM
All the Tech infoi including Service manual for ALL the separate elements of the car are on this forum at the "Tech Dump" sticky under "D2 - Common Problems" thread heading . No cost
(See "Service Manual - Air Conditioner - Sect 7.12 p 166)
Old 20th August 2017, 04:08 PM
mannyo mannyo is offline
The whole manual is available here on this forum, look in the Tech Dump at the top of the topic list, it has everything you ever wanted to know about the D2.
http://forum.a8parts.co.uk/showthread.php?t=9345
Manny
Past
Old 20th August 2017, 04:19 PM
After very generous help from Conquistador, the errors that come up are as follows (which seems like lots of issues !!). Can anyone translate it into what needs fixing? thx
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 M
Component: A8-Klimavollautomat D12
Coding: 00081
Shop #: WSC 02313
VCID: 264580C3C265DF2ECEF-2566
7 Faults Found:
00713 - Centre Left Vent Positioning Motor (V110)
41-00 - Blocked or No Voltage
00657 - Positioning Motor for Central Vents (V102)
00712 - Right Footwell Flap Positioning Motor (V109)
41-10 - Blocked or No Voltage - Intermittent
00715 - Rear Footwell Vent Positioning Motor (V112)
01274 - Air Flow Flap Positioning Motor (V71)
00733 - Potentiometer in Positioning Motor for Rear Footwell Vent (G141)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
