Charge it fully and disconnect it. If you'll be away long enough for there to be any chance of it freezing, remove it from the car and bring it indoors.
The car will be in a little bit of a grump when you reconnect it - you'll need the code for the radio, the one-touch windows will need resetting, and the gearbox ECU will have lost its learned adaptations. A few of the other ECUs will have recorded a T30 voltage too low so its handy to have VCDS on hand to clear those. No harm will come to it though ![]() Personally I would not recommend starting if its not going to be driven. That causes more harm than good as the engine doesn't get properly hot and you end up with condensation in then engine block, gearbox and exhaust, none of which react well to moisture. If it has to sit for a few months, its best for it to be completely dormant. I'd also flush out the screen wash and top it right up with fresh, to reduce the chance of any bugs growing in it. |
Thanks everyone. Appreciate the input.
It's not a good idea to leave car unused for that long parked outside. I would say 3 months maximum without driving if parked outside. Oil that protects metal parts can start breaking down an corrosion can start on things like shock absorbed rods or engine valves. Rubber parts also don't like being left without use for long time. And I am not even talking about things like brake discs or tyres becoming 'square' and vibrating when you start using it again. Starting car for a short while and just idling it to charge battery can definitely be bad for cats and lambdas but it will get the oil flowing around in engine and if you let it warm up and then give it some throttle and keep 2-3k rpm for 5-10 minutes that should clear cats as well. Driving up and down the kerb or even over some wooded planks on the drive if no tax/insurance to go on road will give some exercise to shocks and coat them with a fresh layer of oil.
There are plenty of examples where cars have been standing for longer and are still fine so it depends on individual circumstances. My neighbour had Astra without use for about 1.5 years and gave it to young relative who was studying to be mechanic as a project. The brakes were seized, brake lines corroded, and engine rusted, no compression and not starting, interior full of mould. He spent way more money on it than it was worth but still could not pass emissions on MOT and finally scrapped car in the end.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 27th August 2017 at 04:10 PM. |
Hi,
I have used a cheap solar trickle charger successfully on my D2, when starting running for 10 minutes to get proper hot, running up and down short drive. This has been OK and I will repeat this autumn and winter (Oct - April), got some little snags to fix... ![]() Questions to follow! Robert
3.7 to the stars... D2, LPG kit, March 2000(road tax...) |
Mine is left for circa 2 or 3 months.
I also have a solar trickle charger that kicks out 7A imput. I leave this on the rear parcel shelf and plugged into the rear cigarette lighter, which is permanently live. This will not charge your battery, but will keep it topped up, so make sure your battery is fully charged before leaving the car. David ![]() ![]()
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() ![]() 1997 A8 Quattro Sport - Now sold when S8 FE purchased ![]() |
Thanks Again everyone, will try the solar panel and it will be given a light run up the road every month at least.
Thanks again, I feel much better about it now. |
I bought one of the AA solar panels , came with cig plug and croc clips
worked for me for 3 months |
