Old 27th August 2017, 04:06 PM
It's not a good idea to leave car unused for that long parked outside. I would say 3 months maximum without driving if parked outside. Oil that protects metal parts can start breaking down an corrosion can start on things like shock absorbed rods or engine valves. Rubber parts also don't like being left without use for long time. And I am not even talking about things like brake discs or tyres becoming 'square' and vibrating when you start using it again. Starting car for a short while and just idling it to charge battery can definitely be bad for cats and lambdas but it will get the oil flowing around in engine and if you let it warm up and then give it some throttle and keep 2-3k rpm for 5-10 minutes that should clear cats as well. Driving up and down the kerb or even over some wooded planks on the drive if no tax/insurance to go on road will give some exercise to shocks and coat them with a fresh layer of oil.
There are plenty of examples where cars have been standing for longer and are still fine so it depends on individual circumstances.
My neighbour had Astra without use for about 1.5 years and gave it to young relative who was studying to be mechanic as a project. The brakes were seized, brake lines corroded, and engine rusted, no compression and not starting, interior full of mould. He spent way more money on it than it was worth but still could not pass emissions on MOT and finally scrapped car in the end.
Old 27th August 2017, 06:24 PM
YorkshireBloke's Avatar
Hi,
I have used a cheap solar trickle charger successfully on my D2, when starting running for 10 minutes to get proper hot, running up and down short drive.
This has been OK and I will repeat this autumn and winter (Oct - April), got some little snags to fix...
Questions to follow!
Robert
Old 28th August 2017, 12:11 PM
barzya8 barzya8 is offline
Mine is left for circa 2 or 3 months.
I also have a solar trickle charger that kicks out 7A imput.
I leave this on the rear parcel shelf and plugged into the rear cigarette lighter, which is permanently live.
This will not charge your battery, but will keep it topped up, so make sure your battery is fully charged before leaving the car.
David
Guildford, Surrey
Bose sound system.
Audi Navigation Plus.
20 inch Final Edition alloys
Old 29th August 2017, 09:42 PM
jt racing jt racing is offline
Thanks Again everyone, will try the solar panel and it will be given a light run up the road every month at least.
Thanks again, I feel much better about it now.
Old 30th August 2017, 12:49 PM
oldnick oldnick is offline
I bought one of the AA solar panels , came with cig plug and croc clips
worked for me for 3 months
