Old 1st September 2017, 10:08 AM
lackovicj lackovicj is offline
Post
Thank you
all front vents blow hot and cold air.
rear footwell and pillars on both sides blow air hot and cold air
rear left center vent blows hot and cold air.
rear left nothing at all...no cold no hot no flow even when is set to AUTO
Is possible that only rear right ductwork is disconnected?? at ETKA it shows the pipes are plastic and one module so even they disconnected there should be at least a bit of air going through to the right side.
VAGCOM says rear right blower intermittent mechanical failure but when I opened the rear console up there is nothing mechanical. except digital AC panel.
I am very confused..
I will look again on the ductwork over the weekend.
Thank you
