Old 7th September 2017, 08:53 AM
Not really sure why a debate is needed, Quantum is the brand produced by VW/Audi for their engines so meets the required spec (though as has been said it's probably rebranded Castrol or such like), and it's what Dealers and Audi Independant will use too...so sounds good enough to me..
Well, not everything produced by the dealer is the best quality and I am not very knowledgeable when it comes to engine oils, basically know nothing, so just needed an advice as there is plenty contradicting info online, that's all Brian.
So what you are saying guys is paying extra £70-£80 for 25 litres of Castrol Edge vs Quantum is basically mugging yourself off??
Ok then, I will get 25l of Quantum Longlife III 5W-30.
Last question
How about Quantum Platinum 5W-40?? Is it a better option for cars with higher mileage??
Pug, what I will do then is only one flush at least.
I will drain the oil, put new filter and new oil inc engine flush, run it for 20min, drain oil and change the filter and oil again.
Thank you once again boys for all the advice and comments
Old 7th September 2017, 11:21 AM
Pug Pug is offline
Last question
The 5w40 is not considered long life spec. I can't comment as to whether it would be suitable for your engine.
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 7th September 2017, 01:08 PM
OK guys, so I've just picked from Audi 2x oil filters, fuel filter and other bits inc. new drain plug with washer.
Plan is:
1. Drain oil, fit new filter, fill her up with fresh oil and drive approx 100miles.
2. Then can of Wynns engine flush, run engine for about 20-30min, drain the new oil, fit 2nd new filter and new drain plug, fill with fresh oil.
Done.
Sounds good?
Old 7th September 2017, 03:45 PM
I found this article quite informative:
http://www.oilspecifications.org/art..._explained.php
Old 7th September 2017, 02:20 PM
Last question
Hi Marcin, I don't know anything about oil either only the stuff I read on the internet
If you can get info about Q.Platinum 5W40's HTHS value and NOACK (some kind of volatility test value) and compare it to other oils, this will give you a better indication of if its better for your engine than another oil.
In the oil specs by Audi, BMW, Mercedes, etc, HTHS and NOACK values are very important in meeting the spec. Oil weights such as 30, 40, etc are pretty vague and don't really mean much.
Old 7th September 2017, 04:16 PM
I had 20l delivered today, this was the cheapest I could find, and that was delivered to my door
Old 7th September 2017, 06:35 PM
Yeah I have bought from them before, they are a reputable (as far as any dealer can be) multi franchise dealer in Scotland
Old 8th September 2017, 12:13 PM
This looks useful too, its for USA I couldn't find the UK/Europe bulletin. Must be available somewhere.
https://www.audiusa.com/content/dam/...e-Bulletin.pdf
Old 8th September 2017, 12:17 PM
Interesting thread
https://www.bobistheoilguy.com/forum...or_am_I_wrong?
Name:	VW oil spec.png
Old 8th September 2017, 07:35 PM
This diagram from the oilspecifiation.org site was quite good i thought.
