Just as an update: Looks like all things are sorted out now, no returning codes. I will keep an eye on the ATF level and keep you guys updated.
![]() Last edited by Schaefft; 15th September 2017 at 09:22 AM. |
Rebuild at Mackies or better at ZF in Germany (this is where I go).
Yes, that will cost a lot of money. But it won't be more expensive than the money ![]() Get rid of the car now if you are not prepared for full rebuild. If you're lucky, you can find donor gearbox, but that's lottery. Rebuilt will always be cheaper if you do it immediately after you notice first symptoms. When done, change ATF and filter every year if it's daily driver. That's what I do.
I'd rather drive on left |
Yeah, that's kinda what I am preparing myself for slowly. I would consider the rebuild if the car didn't have other things that will need doing in the future (the timing belt is up next year I believe). A shame really, as I cannot really see any alternative to the S8 for even close the money.
Hi Rico
![]() I would give Mackies a ring and discuss those codes and see what they say, they have the most experience and any advice from experts is good free advice. Good luck with sorting - from someone who has been through the pain! ![]() 18223/P1815 - Pressure Control Valve 1 (N215): Short to Plus Possible Causes Wiring from/to Pressure Control Valve 1 (N215) Short to Plus Pressure Control Valve 1 (N215) faulty Possible Solutions Check Wiring from/to Pressure Control Valve 1 (N215) Check Pressure Control Valve 1 (N215) Check Measuring Blocks Special Notes Pressure Control Valve 1 (N215) might be referred to as Solenoid Valve 4 (N91) Start with checking connectors for corrosion or water damage, in case of 01V transmission pay special attention to 16-pin connector between valve body and wiring harness.
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 7th September 2017 at 11:09 AM. |
I've had a look at the TCM today to see if there is anything wrong with it. Everything looks fine, nice and dry. Definitely still the original unit. I also had a look underneath the car (as much as its possible with it being on the ground) to see if there is an ATF leak that could cause the slipping gear related codes, but everything is so oily that its impossible to tell where its coming from. I cleared the codes and took for a very short drive shifting through all gears as often as possible, still driving perfectly fine and the only code that came back is the MAF (16486/P0102 "Signal too Low"). I haven't checked the wires properly yet but will do that asap. I need notice this zip-tie around the connector though, is this normal?
![]() I guess that confirms that the gearbox codes above are intermittent. Maybe there's still a chance to the ATF level is just too low? Last edited by Schaefft; 8th September 2017 at 08:24 PM. |
A bung MAF will give gearbox problems, as the ECU and TCU use the engine load/torque data that can be derived from the MAF for shifting purposes.
Buy a new MAF. A quick and dirty test is to do a WOT run from standing start. You will get a rough 1-2 shift with a dud MAF. P.S. zip tie is normal
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
