I've got a very similar one (from Lidl a while back), and it's great. Buy 5w30 507 oil when I see it cheap, and can just pick up a filter and change the oil quickly with little mess whenever it needs doing.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
I have full service from audi but that b**** cant tell what oit they have put in,,so I decided to pump it out and use 5w30 as you said however when I start the engine from cold(at morning or after 3-4 h of not using it) it sounds like metalic lid on boiling pot of water,,I read about it and it looks the oil slip back down to the pan and engine makes the horible noise until it bulds up the preasure (1-2 seconds)....I might change it into something ticker in a few months.
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS Previous : Chevrolet Blazer 2001 LT 4.3 petrol ![]() |
lacovicj; the key point from JohnMed's comment is that you should make sure you get oil that meets VAG spec. 507.00 [Longlife Diesel] or 504.00 [Longlife Petrol].
I note that all the oils I see [and use] meet both specs. Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
I have checked that before using it also audi webside recommends it. But not knowing if audi dealer put 0w30, 5w30, 5w40, 10w40 and there is too much confuson I went for the 5w30 C3. I would like to still get as much opinions on what oil to use as my A8 is 3.7 petrol than more common TDI. There is too much confusion on the engine oil especially when the manual says something different ![]() ![]()
