Old 13th July 2010, 07:20 AM
Originally Posted by Night Train View Post
Should I disconnect the battery before removing the rear seat, If I don't, does anyone know if there's a danger of triggering the airbags accidentally?
I have removed the rear seat without removing the battery with no problems. You may wish to test some of the circutry prior to re-installing the interior so the battery will have to be reconnected at some point. If you turn on the ignition with the seat disconnected you'll throw a fault and will need VagCom to reset it once you are done.
Old 13th July 2010, 07:24 AM
Night Train's Avatar
Cheers Mike, thanks for the info
Other vehicles
Oh Yes....... The '98 PF S8!
