Coding is wrong in module 0x13
is that the abs module? could not do anything with that coding wise unless I'm doing it wrong
had another go this morning found a code on google for acc but still no luck nothing I do seems to work
![]() so that's it for me now 500 down the drain again don't even know if gateway is right 4e0907468b |
Not ABS but the radar module. It's currently coded for a trailer hitch. Your scan, now deleted, didn't show this. I can't help too much without the full scan.
ill try another scan laptop wouldn't let me save it this morning
Saturday,30,September,2017,13:16:26:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 15.7.0.2 Data version: 20150820 www.Ross-Tech.com VIN: WAUZZZ4E65N002074 License Plate: T22KRL Mileage: 187180km-116308mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 66 67 72 76 77 VIN: WAUZZZ4E65N002074 Mileage: 187180km-116308miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 0010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1D-Driver Ident. -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 66-Seat, Rear -- Status: Cannot be reached 1100 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 07C-910-018-BHT1.lbl Part No SW: 4E0 910 018 HW: 4E0 906 018 Component: 6.0L W12/4V A ª0110 Revision: -------- Serial number: AUX3Z0D4341645 Coding: 0011773 Shop #: WSC 00353 210 62620 VCID: 5C52777F5F24D7F2F9A6A1-8008 No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 J HW: 09E 927 156 A Component: AG6 09E 6,0L4V RdW 0060 Revision: 00000001 Serial number: 0037043 Coding: 0000001 Shop #: WSC 00353 210 62620 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD Component: ESP 5.7 allrad H44 0330 Coding: 0007637 Shop #: WSC 12345 000 00000 VCID: 23A00C8322DAA80AF85CD2-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D4341645 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 585A6B6F2B1C3BD2DD4E9D-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 3 Faults Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 1 Reset counter: 72 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00182 - Luggage Compartment Access/Start Authorization Antenna (R137) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063968 Shop #: WSC 00000 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 186272 km Time Indication: 0 Date: 2017.07.03 Time: 01:14:26 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300FF047536342 Coding: 0000002 Shop #: WSC 00353 210 62620 VCID: 3A9ED1E7B550C9C2CB7AD7-806E Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 318EG047506302 Subsystem 3 - Serial number: 7405.05.040000000000010069ÿ Subsystem 4 - Serial number: 010069ÿ 2 Faults Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 31 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 11:02:00 01319 - Control Module for Distance Control (J428) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 32 Mileage: 187181 km Time Indication: 0 Date: 2017.09.30 Time: 11:11:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 A HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0300 Revision: 00000025 Serial number: 00000000046407 Coding: 0389369 Shop #: WSC 02311 785 00200 VCID: 1BD034631AAA90CA302C7A-804E 4 Faults Found: 01855 - Temperature Sensor for Heated Seat; Left Front (G344) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 30 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 20:01:56 Freeze Frame: Temperature: 20.0°C 01856 - Temperature Sensor for Heated Seat; Front Right (G345) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 30 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 20:01:56 Freeze Frame: Temperature: 20.0°C 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 13 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.28 Time: 17:44:22 Freeze Frame: Voltage: 12.70 V 01854 - Heated Seat; Front Right (Z46) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 69 Mileage: 187127 km Time Indication: 0 Date: 2017.09.29 Time: 10:31:19 Freeze Frame: Temperature: 14.0°C ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 J HW: 4E2 955 113 B Component: ILM Fahrer H12 0190 Coding: 0133121 Shop #: WSC 02313 785 00200 VCID: 2F88F0B37E121C6A6CE45E-807A Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0040 Coding: 00141886 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000000 Serial number: AUZ5ZBC1015724 Shop #: WSC 00000 000 00000 VCID: 1CD2377F1FA497F2392661-8048 1 Fault Found: 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 4 Fault Frequency: 254 Reset counter: 119 Mileage: 275443 km Time Indication: 0 Date: 2017.03.02 Time: 17:53:11 ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276W7101465 Coding: 0000001 Shop #: WSC 02152 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: 07C-910-018-BHT2.lbl Part No SW: 4E0 910 018 HW: 4E0 906 018 Component: 6.0L W12/4V A ª0110 Revision: -------- Serial number: AUX3Z0D4341645 Coding: 0011773 Shop #: WSC 00353 210 62620 VCID: 5C52777F5F24D7F2F9A6A1-8008 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 4E0 910 561 F HW: 4E0 907 561 F Component: ABSTANDSREGELUNGH03 0020 Coding: 0041218 Shop #: WSC 02313 785 00200 VCID: 25A4129B2CEE563A9648CC-8070 2 Faults Found: 01517 - Control Module for Trailer/Towing Sensor (J345) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10110100 Fault Priority: 5 Fault Frequency: 5 Reset counter: 71 Mileage: 187176 km Time Indication: 0 Date: 2017.09.30 Time: 00:44:00 Freeze Frame: Temperature: 20.0°C Voltage: 12.67 V Bin. Bits: 00100000 01044 - Control Module Incorrectly Coded 000 - - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 5 Fault Frequency: 6 Reset counter: 32 Mileage: 187176 km Time Indication: 0 Date: 2017.09.30 Time: 11:01:00 Freeze Frame: Temperature: 18.0°C Voltage: 11.14 V Bin. Bits: 00100000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0430707 Shop #: WSC 02313 785 00200 VCID: 63204C83625AE80AB8DC12-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112151 Shop #: WSC 02311 785 00200 VCID: 6524529B6C6E963A56C80C-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H04 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 931 E HW: 4E0 920 931 E Component: KOMBIINSTR. VDO H70 0400 Revision: D01 Serial number: AUDID3E5000168 Coding: 0032443 Shop #: WSC 00999 444 64523 VCID: 25A4129B2CEE563A9648CC-8070 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 B Component: Gateway H07 0070 Revision: 07 Serial number: 15004048120502 Coding: FEFFFFFC3B7D04 Shop #: WSC 00720 210 86425 VCID: 6524529B6C6E963A56C80C-8030 1 Fault Found: 00462 - Control Module for Seat Memory; Rear (J522) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 42 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:35:57 ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0010 Revision: 01000101 Serial number: 11042005084300 Shop #: WSC 00000 000 00000 VCID: 1FA800730EB28CEADC040E-804A 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.27 Time: 20:03:40 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 0 Reset counter: 70 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:31:32 ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2BB0E4A34A0AA04A408C8A-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H03 0140 Revision: 01403903 Serial number: AUX3Z0D4341645 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 585A6B6F2B1C3BD2DD4E9D-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 3 Faults Found: 00179 - Access/Start Authorization Antenna; Drivers Side (R134) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 2 Reset counter: 32 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 00182 - Luggage Compartment Access/Start Authorization Antenna (R137) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 30 Mileage: 187120 km Time Indication: 0 Date: 2017.09.29 Time: 10:32:18 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 B Component: KLIMA-STG. FOND 015 0220 Revision: 00000018 Serial number: 00000000026849 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 612C468B7846FA1AAAF078-8034 2 Faults Found: 02291 - Control Module for Seat Vent; Rear; Driver Side (J674) 004 - No Signal/Communication 02292 - Control Module for Seat Vent; Rear Passenger Side (J675) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 00353 210 89229 VCID: 28BA1BAF5BFC4B52ADAEED-807C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H01 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063982 Shop #: WSC 00000 785 00200 VCID: 24A20F9F27D4AF328156D9-8070 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 32 Mileage: 186272 km Time Indication: 0 Date: 2017.07.04 Time: 00:30:41 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H43 1060 Revision: 00000000 Serial number: 353FY047523897 Shop #: WSC 02313 785 00200 VCID: 3B90D4E3BA6AF0CAD06CDA-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000413900087 Coding: 0036070 Shop #: WSC 02313 785 00200 VCID: 1DD43A7B04BE9EFACE1814-8048 2 Faults Found: 00211 - Control Circuit for Rear Illumination Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 2 Reset counter: 28 Mileage: 187104 km Time Indication: 0 Date: 2017.09.23 Time: 00:55:00 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 0 Fault Frequency: 3 Reset counter: 71 Mileage: 187124 km Time Indication: 0 Date: 2017.09.28 Time: 17:44:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRMH01 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 20AA038F33CCB312E57E35-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040406080130 Coding: 0004857 Shop #: WSC 02313 785 00200 VCID: 27B8189356E2442AA4B4E6-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000003257 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000042258 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1ED63D7709B885E2D7121B-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRMH01 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 20AA038F33CCB312E57E35-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000631 Shop #: WSC 00999 444 64523 VCID: 1DD43A7B04BE9EFACE1814-8048 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000003 Shop #: WSC 02311 785 00200 VCID: 622E49877D40E102B3EA6F-8036 1 Fault Found: 02235 - Stationary Cornering Lamp (Left) (M51) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 70 Mileage: 187128 km Time Indication: 0 Date: 2017.09.27 Time: 19:20:35 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 B Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304FS047595508 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 318CF6CB68260A9A7AD048-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 D HW: 4E0 919 148 Component: R0078 TVhybridTuner 0440 Revision: R0H06000 Serial number: 76300800403102 Coding: 0000303 Shop #: WSC 31414 790 00001 VCID: 24A20F9F27D4AF328156D9-8070 4 Faults Found: 00863 - Antenna 1 for TV (R55) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 21 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:33 00864 - Antenna 2 for TV (R56) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 20 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 00865 - Antenna 3 for TV (R57) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 19 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 00866 - Antenna 4 for TV (R58) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 5 Fault Frequency: 21 Reset counter: 32 Mileage: 187127 km Time Indication: 0 Date: 2017.09.27 Time: 19:48:31 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H11 0510 Revision: 00000000 Serial number: 00000000002193 Shop #: WSC 00353 210 62620 VCID: 20AA038F33CCB312E57E35-8074 Subsystem 1 - Part No: 000 915 105 DL Component: von VA0 350117H281 Coding: 303030393135313035444C56413033353031313748323831 Shop #: WSC 12345 128 00289 5 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 255 Time Indication: 0 Date: 2017.09.30 Time: 01:39:22 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:26 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:36 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 01:58:46 02256 - Quiescent Current 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 7 Fault Frequency: 1 Reset counter: 71 Mileage: 187177 km Time Indication: 0 Date: 2017.09.30 Time: 07:56:31 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 1ED63D7709B885E2D7121B-804A 3 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 221 Mileage: 187104 km Time Indication: 0 Date: 2017.09.08 Time: 10:47:56 02130 - Interior Door Lighting 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 72 Mileage: 187104 km Time Indication: 0 Date: 2017.09.17 Time: 18:43:08 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 68 Mileage: 187104 km Time Indication: 0 Date: 2017.09.20 Time: 10:43:30 ------------------------------------------------------------------------------- Address 66: Seat, Rear Cannot be reached ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000403240081 Shop #: WSC 12336 024 394758 VCID: 3686C5D781482DA22F2203-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0032751 Shop #: WSC 02311 785 00200 VCID: 1ED63D7709B885E2D7121B-804A 2 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 221 Mileage: 187104 km Time Indication: 0 Date: 2017.09.08 Time: 10:47:56 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 68 Mileage: 187104 km Time Indication: 0 Date: 2017.09.20 Time: 10:43:30 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08730413301313 Coding: 0101108 Shop #: WSC 02313 785 00200 VCID: 21AC068B38C6BA1AEA7038-8074 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 K HW: 4E0 862 335 Component: Handyvorb2 H18 0950 Revision: 00000000 Serial number: 00000005025638 Coding: 0010900 Shop #: WSC 02335 758 00200 VCID: 2ABEE1A745F07942BB9A87-807E No fault code found. End-------------------------(Elapsed Time: 04:06)-------------------------- |
Some rather strange faults there. All over the place date and time wise.
I would do as Sean (steamship) suggested, clear all the faults and start again, but this time time clear manually one controller at a time. If any of the controllers fail to clear all it's faults, go back to that controler and try again after you have cleared all the others. I have found on occasions that the controllers have reported the faults found by other units, causing some confusion. Simply put; knickers in a knot syndrome. Try and not give up, it can be very frustrating. Remember before computers came along all these problems would not have been "found" and logged and you would have been happily driving around in ignorance. Now you are on a steep learning path. Good luck with it.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by Architex_mA8tey; 30th September 2017 at 09:40 PM. |
just an update for all and thankyou for all your help I was getting a little stressed to say the least
![]() ![]() had to modify front grill as finding one with acc seems rare lol |
