D3 Gearboxes are pretty robust but at 140k, an ATF change would be a good move even if you didn't have any issues.
Most important thing here is to make sure you don't give the job to someone that doesn't know what they are doing.... I'm not in the UK but I have used an Audi Dealer to carry out ATF + Filter changes 3 times on my old D3 over the years. They dropped the pan, replaced filter etc. but I think it cost about €500 everytime. The fluid is expensive. |
There is a different fluid that can be put in but it requires a full flush with the new stuff - I think its called lifeguard 8 instead of 6 - then the gearbox needs a software update to deal with the different viscosity and friction coefficients of the different oil. As far as I'm aware the oil has been specially developed for high mileage gearboxes. There is a technical bulletin from Audi for the change. I also believe that there arent many places that do the full flush - two names consistently come up, one in Glasgow and one in chester and it is very expensive due to the amount of fluid required (double the usual amount). A question I have tried to get answered is whether a normal fluid and filter change with the same fluid as filled from the factory would restore the gearbox to the smooth slick gearbox it should be or whether it would wreck the box. The consensus opinion is that maybe it would maybe it wouldnt! The fluid should be inspected first. If it is black and stinks, then there is a good chance that it is the particles of clutch friction material and tiny metallic particles floating around in the fluid that give it sufficient frictional properties to keep the gearbox working and changing for clean new stuff with a new filter will cause it to slip and basically finish it off. If the oil has never been changed in 140k miles (like mine probably hasnt), its a gamble as to what will happen. The other possibility; assuming a successful fluid and filter change (drop and clean pan, change filter, torque converter still full, refill with same type of oil) which improves the gearbox function, increases smoothness etc but on a gearbox that was hooting. A question Ive never managed to get an answer for is whether the hooting will still be there and will it further damage the gearbox or will it improve? What damage does the hooting actually do? I have a good local autobox specialist who i would trust to do a full fluid change and fliter change. I can get the oil at a good price from my dad's work and I already have the filter, so I would just be paying for time. I'm going to take the car in and get some advice from them and see what they think. maybe get a sample taken of the oil to see what condition it is in. Until I get the hot start problem sorted on this car though I dont want to spend much on it, certainly not the £600+ that I would be charged in glasgow. My A4 cabrio 3.0 tdi has the same gearbox but at only 30k miles. It is smooth as butter, you cant ever feel a gearchange and really is a joy. when you use the paddle shift the gearchanges are totally different, fast and sporty whereas on auto they are clutched in by the TCC giving smooth smooth changes. Its a lot to think about. I'd be interested to see what you decide and how it work out for you of you go down the route of a standard oil and filter change. It sounds like your gearbox is hooting more often than mine. Mine tends to only really do it around third gear and on high loads, full throttle acceleration and changes going up very steep hills. gill |
Thank you for the long write up. I just went through the paperwork I received with the car..I am the second former keeper and service book is filled with audi stamps since new. The book say's Audi did ATF change at 37K which was 103k ago. Then the car was off audi's system and maintenance from 74K and returned at 111k(4 years later) I contacted audi and they said they not able to tell what has been done on the car in that period. Since 2011(111k on the clock) until today the car did 38k miles. The thing is, the car seems to change gears smoothly in all gears but the hoot is just annoying and want to get rid before it become major problem. £220(ATF oil+filter) is a fixed price at audi if my garage beat Audi's price I will get it change with same fluid over there...If the tranny dies by feb.2018 I will claim the repair through my extended warranty(hopefully) or Should I go to audi get it change and if something goes wrong with the tranny within a month or so audi should take a full responsibility as they should be aware not to replace ATF fluid at that high milage car. What do you think ![]() ![]()
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS Previous : Chevrolet Blazer 2001 LT 4.3 petrol ![]() |
A grand, or 2 maybe. After a fight.....I'd check your small print quite carefully..... ?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
PS: I got 6 moths of 3rd party warranty when I bought the car.
£220 sounds "too cheap" for a proper job given the price of the parts required and amount of labour involved. I'd be suspicious.
It's very unlikely but if the gearbox does pack up, I think you'll be well past the £1000 claim limit to get it sorted. I'd be considering finding another D3 at that stage. |
So, it sounds to me from experience like a torque converter/slip/hard shifting and the mileage for it is about right.
Not everyone may agree, but when you change the oil, put a bottle of this. http://www.ebay.co.uk/itm/Lucas-Tran...8AAOSwcUBYJLIr Oil change and Lucas has solved this problem on countless A8's and Q7, some of course just needed new oil. I've had same problem and after 300-400miles it was gone and never came back. If you are in London then these are the guys to do it. http://www.audivwsc.co.uk/ Bunch of ex-Audi Master Technicians from Europe and US who got feed up with Audi politics and way of doing things and charges who got together and now became one of the most if not the most trusted independent garage.
Ou-key I am back after a while..
So let's get back to the ATF oil change.. As I mentioned previously my gearbox had kind of rusty hoot (one-second noise only) while flooring the pedal. I went to my garage and watched the person to replace the fluid 6L(ZF LG6) and filter(Vaico) and I also added 710ml Lucas gearbox Antislip liquid as mentioned by one of our forum members. We have inspected drained fluid(fairly good, goldish and not smelly) so in good condition. Replaced filter, new gasket and put gearbox pan back on. Added Lucas fluid,,then about 4,5L of LG6 fluid(until it started to leak through fill plug) started the engine and let it idle for about 5 min,guy added some more fluid,,I run it through the gears a bit and put in in D for 1-2 min while he kept adding the rest of the fluid until it started over leak again. Tighten the fill plug and took it for a test drive and guess what?? The noise has gone and tranny became more responsive. PS: the guy knows quite alot on Audi's,MB,BMW. We went for a test drive before the fluid change, he mentioned solenoids could be the problem and the oil might fix or not.He has got a company in Bulgaria they repair the solenoid panel(my audi for £280 or replace the whole solenoid panel for £480 in case I needed to).however, I went there prepared and scanned gearbox with VCDS and didnt find any problematic solenoids on the tranny not even after the fluid change so all good. He also mentioned if you low on fluid your car will not move while in D without pressing the pedal due low pressure. The conclusion is the fluid makes a difference. and I can highly advise getting it replaced if you in a doubt. Cost of the job includes filter and 6L LG6 £280. PS2: I went to audi and they mentioned they dont replace Tiptronic fluid only the Multi and S tronic.. When I mention my service book says the fluid has been changed on 40K miles they said someone must have ticked the wrong box..F****s ![]()
I'm not aware of anyone doing an oil change (correctly) on a D3 and making the gearbox any worse.
I personally did the 4.2 Tdi that Oli is currently selling at around 100k and it went from pretty good anyway to feeling brand new with a simple oil and filter change, clean of pan etc. I really can't emphasis enough times not to your use Audi however for the job, as they'll give 'the simple job' to the freshest student in the place who won't give too hoots whether the oil level is spot on, or likely go to the efforts of cleaning the pan. From distant memory, I think the W12 and 4.2 Tdi use different gearbox oil due to the torque, but the rest are cheaper stuff..... The hoot will be a semi-blocked filter that is starving the box of oil creating a high pitched sucking sound as its getting air, not oil. I would imagine the issue can only get worse rather than better if left. If you speak to a decent transmission specialist, and discuss the symptoms hopefully they will give you some sensible feedback and suggest the best course of action. Audi won't do this. They have no idea whatsoever about gearboxes. Its a part number. If its bust. They change the whole part...! Did I mention, don't take it to Audi ? And don't take it to joe bloggs regular car garage either. This isn't a Toyota. Take it to a *transmission specialist* who fixes these things day in, day out.
I am also sceptical about taking it to Audi with knowing how many “freshies” students going to work on my car and not give a s*** about the work done. I wish to have a roof above my car to do it myself It cant be that different than on Chevy truck I use to own.
