Old 1st September 2017, 08:39 AM
lackovicj lackovicj is offline
Default Light smoke
HI
When I park after the drive (30miles) I can see light smoke coming from the side of the engine where the oil cap is, it looks like from underneath a pipe/hose which runs on the side along the engine block. Light smoke like when oil is dripping on hot pipe. I might make some pictures if needed.
A8 D3 2003 3.7 petrol
Anybody knows what to look for??
Thank you
Old 18th September 2017, 04:33 PM
just an update...
smoke started being sucked by the polen filter and entering cabin...sometimes annoying especial when breaking and turning right when the oil get pushed on the left side of the engine. not noticable when the AC is on for some reason.
took it to the garage... aparently rockercover gasket... but that needs to be confirmed so car is booked in and mechanic will look at it from the underneath.
oil is apparently dripping on the manifold and thats why is burning light sticky smoke,,however there is not oil leak underneath of the engine
Audi A8 D3 2003 3.7 V8 petrol, Oyster gray with black interior
19" alloy, Sport suspension transmission and seats, HID headlights, Phone in armrest, 4zone AC, Sat-Nav, TV, Dimmable exterior mirrors, VCDS
Previous : Chevrolet Blazer 2001 LT 4.3 petrol
Old 2nd October 2017, 07:40 AM
Update no.2
Car left at the garage this morning.(finally)
They going to replace camshaft seal (what is causing oil to drip on the exhaust system and producing oil-burning smell) plus rocker-cover gasket.
So next update is going to be a happy update.
Old 31st October 2017, 11:31 AM
So garage replaced rockercover gasket and camsahft seal....well they replaced rockercover but not camshaft cap...so i took it back as it smoked still..
Now the cap is replaced and the smoke gone..moreless...
time to time I can smell abit of burning smell still...I have been told it can be a oil resitude ...going to leave it for a time being...
I still think the camshaft cap is not enough..I would personally replace the camshaft seal which is not apparently difficult to do by other a member of other forum.
Why the garages always trying to take a shortcut..
Old 1st November 2017, 09:46 AM
Simonbartlett Simonbartlett is offline
Maybe a silly question but it’s not just the aux heater is it, as it gets colder they will be starting up. Sometimes when first starting for the winter they smoke a lot.
Owner of a 2008 A8 3.0tdi SE
Old 1st November 2017, 10:31 AM
Picture 0 show where the light smoke coming from (smells like when the oil drips on hot surface and then evaporate)
Picture 1 show old cap with a leak (It leaks on the hose then it slides on the hose then drip on the manifold and evaporate...that's what I think)
Picture 2 show new camshaft cap (no leak but occasionally smell burning oil)
I will have to probably buy inspection camera to have a better look on the side of the engine block.
ID:	17426   Click image for larger version
ID:	17427   Click image for larger version
Old 18th November 2017, 08:14 PM
Looks is still dripping through some stud located on pasangers side near firewall, from underneeth of the last screw which holds valve cover..
What is thats stud for?? Does it have seal or something?? Sorry for the pictures they are made by inspection camera from very difficult angle..
ID:	17493   Click image for larger version
ID:	17494   Click image for larger version
ID:	17495   Click image for larger version
ID:	17496   Click image for larger version
