Old 3rd October 2017, 08:17 PM
26pin gateway connector on the left. Wire a "13x2 dupont" with male pins (both centre) to the 20pin red gateway (right) and job done
Matt
Old 4th October 2017, 08:11 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Wrong way round mate.
Need to plug the 26pin plug from the car in to the 26pin socket and then plug the 20pin plug in to the 20pin socket in to the 20pin gateway.
That loom you posted would be great for plugging two gateways together.
[center]
06 3.0TDI Quattro:
Options:
Old 4th October 2017, 08:38 AM
Photoshop required as maybe my text didn't explain.
Matt
Old 4th October 2017, 08:42 AM
ScottD3's Avatar
Ahhhh I see what you mean now.
Didn't think of that.
I'll have a rummage through my cable box and see what I might have.
[center]
06 3.0TDI Quattro:
Options:
Old 4th October 2017, 08:43 AM
I made something similar, but used right angle header pins, to connect the gateway to a logic analyser.
ID:	17140   Click image for larger version
Matt
Old 4th October 2017, 08:45 AM
Lol had this same conversation yesterday.
What he want is a socket receptacle from a 26 pin gateway so he can make a loom adaptor to go from a d3 that has a 26 pin gateway to a newer 20 pin gateway.
But I suspect there is no matching receptacle for cable harness wiring
Old 4th October 2017, 08:47 AM
What he want is a socket receptacle from a 26 pin gateway so he can make a look adaptor to go from a d3 that has a 26 pin gateway to a newer 20 pin gateway
I tried to re purpose a can gateway but it's fiddly. Once it's removed off the gateway PCB it falls apart.
Matt
Old 4th October 2017, 09:10 AM
Correct. You have to make a something custom. Once my adapter is connected it's really secure, hence the loop of electrical tape to pull it out.
Matt
Old 4th October 2017, 09:28 AM
Could the pcb not be hacked to stay with the socket or a new one made?
Old 4th October 2017, 09:49 AM
Yes. The housing that the plug inserts into is separate to the pins, so the section of PCB that holds both in place must be retained. Then you're into soldering new wires, time, getting a bit bulky....
What I posted earlier works and is only terminal crimping. Downside is that it could be inserted 180° out, but we're all smart folk on here not to do that
Matt
