Old 10th October 2017, 12:30 PM
Jon_viola Jon_viola is offline
Thanks for your help. No issues at the moment.
Which fluid should I use? Fluid and filter from Audi? What’s the rough cost of parts?
2007 4.2tdi Quattro Sport.
Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed.
Old 10th October 2017, 12:33 PM
All from Audi or TPS. Labour and parts should come to around £350.
Old 10th October 2017, 12:40 PM
Ok thanks. How much fluid and what type?
Old 10th October 2017, 12:45 PM
G055005A2 - 10l
But wait for others to confirm the part number.
Old 10th October 2017, 01:41 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I’ve never been sure what to do for the best. Mine’s on 142k, and is faultless.
Not sure if it’s been changed, imagine not although it had FASH til 100k. Isn’t there a school of thought that it’s not entirely necessary and/or changing to newer fluid needs a SW update to the ‘box’s ECU?
2007 Mini Cooper S R56
Old 10th October 2017, 01:46 PM
If your gearbox is faultless than it's only recommended to just replace oil like for like with new filter, same spec oil gearbox was filled in at the factory.
I know engine is different, but would you not change the engine oil if it's running faultlessly??
ZF clearly states to replace the oil either after 100,000 or 7 years, which ever is first.
Old 10th October 2017, 01:49 PM
Johnmed's Avatar
Good point. I do change my oil within every 10k miles. Which is probably overkill with 507.
I just have a niggle, I think I’ve read something somewhere of faults after fluid change with gearboxes.
Edit: I know ZF make them, but don’t Audi et al still suggest they’re ‘sealed for life’?
