Old 9th October 2017, 08:55 AM
27litres's Avatar
27litres 27litres is offline
It's not that difficult, it just has to be done right.
I'm sure MJ will have it in hand.
It's a very clever, yet tricky design due to the saddle tank design of the fuel tank and only a single pump. I've had mine out twice (eventually finding the problem not to be the pump!).
Even Audi techs get this installation wrong and Audi switched to a more conventional two pump system for the D3.
Edit: beaten to the punch by MJ herself!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 9th October 2017, 08:09 PM
Front brakes this evening.
Blasted and painted the caliper bracketry since I'm not bolting old rusty brackets to shiny new calipers!
Assembled with new hose ready to go back on
Back on the car with new Pagid disc and pads. The Pagid discs are coated from the factory so they stay looking good for longer
Old 9th October 2017, 08:55 PM
27litres's Avatar
You might be able to answer this Michaela,
The loop of wire attached to the caliper bracket: I've seen this on several cars I've had, is it there literally for hanging the caliper onto the spring with a hook for use during pad/disc changes?
Ah, hang on... Forget all that! It's there to guide the hose during lock-to-lock on the steering and prevent it pinching or scraping or going anywhere undesirable isn't it!
That makes far more sense as to why they'd bother fitting it...
Using it to hang the caliper is just an unintended benefit!
Marty
Family:
Sold:
1997 Audi A4
Old 9th October 2017, 09:26 PM
I have no idea why its there tbh. Protecting the hose is as good a reason as any
Old 10th October 2017, 03:02 PM
johnny_quattro's Avatar
The discs look very similar to Meyle HD to me... Is it wrong to lust after such nice brake discs? I've always liked the look of those. With regard to the Pagid pads, my garage replaced my previous front set after squealing like a pig and they told me they were replaced with Pagid pads. I'd not really heard of them before but they certainly did the trick. Thanks again for all the regular updates MJ on this. The car being 'fettled' is absolutely perfect for us all to see what's going on, as it provides a nice contrast on the photos due to the vibrant red colour. I have to admit that it looks like a new car. The owner will be like a dog with two tails when it's finished, no doubt.
Old 13th October 2017, 07:47 PM
Sorry I've been slacking on the updates The Pizza Dude just arrived at the workshop so here's a big one to compensate.
Electronics box repair - I've shown this before, but again for those who may have missed it.
Where the inserts have come out, drill the hole out to 7mm
Then countersink a little by hand with a 12mm
Then you need some of these guys - Type D threaded inserts
Screw them in the new holes, flush with the box
Fixed
I've bought new screws for the cover. I'll show them tomorrow.
Big Red ventured out in to the daylight for the first time in a month so she could turn round ready for the next few jobs.
This
Cleaned off some underseal
The metal had stretched so I had to cut the edge back a little so the bits would go flush again. Had to resort to a self-tapper to pull the sprag out. I don't know what grade this stuff is, but its amazingly hard for 1mm thick. It was not fun to work with!
Got it flush
Prior to welding, I removed the arch liner and the two body bungs
So I could remove all this highly flammable expanding foam!
The local tig guy came by and welded it up. It was quite a tricky job since the panel was so thin, but attached to a 2 ton heatsink! I should have taken off the underseal a bit further I think.
I'll flatten this off a bit tomorrow and feather the underseal, then re-prime and try to match in some spray-on underseal.
Pulled the rear suspension off to do the bushes
The bushes in the bottom of the hub just popped out with a screwdriver! Proper fubar
The ones in the lower arm weren't much better although the alloy sleeves needed a little persuading
Definitely time for replacement. I made some tools to get them out and back in again
Cleaned up the arm ready for the new bushes
Push them in using the special tools
Ready to go back on
Old 13th October 2017, 07:54 PM
Oh, something else turned up in the workshop this week too...
Old 13th October 2017, 08:14 PM
Spanker's Avatar
Spanker Spanker is online now
It's really nice to see the car again. I was getting withdrawal symptoms
And how strange to see it with those 5 spoke wheels.
That weld seems to have gone well and I'm sure with some underseal over it the MOT inspector won't even know what was there previously.
I am not familiar with those new shiny bits that were in your second post.
Is it something I have spent some money on??
(BTW your gearbox is being collected on Sunday morning).
Dean
Old 13th October 2017, 08:55 PM
Would you believe they came on those 16" wheels in some other markets? They are comically skinny for such a big car. Your 20s came straight off and went in to the store room as soon as the car went up in the air. They are waaay too nice to be kicking around the workshop!
There's very little distortion round the weld so with it finished at least the shape should be barely detectable. Time will tell whether I can match the underseal finish though.
The mounts in the second post are not for your car - they are for the next big project
Old 13th October 2017, 09:56 PM
27litres's Avatar
V6 engine mounts?
My first thought was gearbox mounts, but you said they were NLA. Would also expect a gearbox mount to be a rear cradle type, but on an alloy car...
Marty
Family:
Sold:
1997 Audi A4
