Old 2nd November 2017, 05:19 PM
Spanker's Avatar
Spanker Spanker is offline
I've done the ones in bold. Reversing light is so much better now. Also fitted a second fog light so I have one each side.
(Plus , for a while, the numberplate bulbs, though I've now reverted these - what's the point when the plate is yellow!
Saw no point in doing any of those, glad I didn't try. Though what I have done is use silvered (non-orange when off) front indicator bulbs.
Sorry to jump on an old thread, but what bulbs did you use for the side lights and did they give a white light (like the Xenons) to replace the odd yellowy light from the stock bulbs?
Whilst with MJ the other weekend, we tried some replacement bulbs that she had ordered for the very job but the pins weren't correct. The pins on the replacements were directly opposite each other on the bulb, whereas the stock holder appear to be built for bulbs that have the pins not-quite opposite each other (if that makes sense). And the amount of space you have to play with regards to the dimensions of the bulb is minimal.
So I would love to know the exact bulbs that you guys used to give a white glow (assuming you got a white glow).
TIA
Dean
Old 2nd November 2017, 05:25 PM
Spanker's Avatar
Ah!
I should have done more digging.
Found this thread:
http://forum.a8parts.co.uk/showpost....5&postcount=61
So I will use this as my starting point.
The eBay link points to something no longer listed so I can search for something similar unless someone beats me to it.
Update: These look like them (offset pins). I'll order a set and will update this post should they do the trick.
http://www.ebay.co.uk/itm/2x-5-SMD-L...UAAOSw9NxTxSf8
Dean
Old 2nd November 2017, 05:44 PM
Those may not fit, it really is a tight squeeze! But let us know how you get on.
That's why I used the type I bought, the emitter section is definitely slimmer than the metal base. And they are still working after nearly 5 years!
These might fit, but are a bit long: https://www.ebay.co.uk/itm/253204656719
Old 14th November 2017, 08:11 AM
And they didn't.
