Old 6th December 2017, 10:30 AM
ulfilias ulfilias is offline
Am guessing this Webasto thinggy was an add on or a TDI thing ???
And I don't have it on my 4.2 V8 ???
Current :
Previous :
Also :
Old 6th December 2017, 10:48 AM
Standard on the TDI - as the engines are so efficient they take too long to heat up, no such issue with the petrol models
Old 6th December 2017, 12:03 PM
I tried your way this morning Snap and it seemed to work.
Now waiting for an all white morning to put it to the test. Will let you know.
In the meantime I'm trying to work out where I can fix my remote receiver.
Probably easier to put the telestart module onto the webasto. You can get them on ebay and allegro.pl for VW, skoda, etc..
Mechanico Lee - I tried to take the magnet off the motor but was unable to counter-hold enough to undo the nut.
Also could not disassemble the valve block any further
Old 6th December 2017, 02:18 PM
You say that.....May be when the system is all working!!!
I've often found you need to do a few miles in petrol cars. I bought a plug in fan heater years back. I should have just burnt the tenner as i'd have got more warmth!
And this remote pre-heat idea sounds awesome
Current :
Previous :
Also :
Old 6th December 2017, 03:06 PM
Attachment 17594
Here is a guide to upgrading Aux heater to Parking heater - Luckily I saved the page as a PDF before the images went AWOL!
Old 6th December 2017, 04:07 PM
Is that right? and there was me thinking it was because the derv's were made out of heavy old cast steel that takes ages to warm up.
Old 11th December 2017, 11:03 AM
Hi There,
Just picked up a 4E0959617A - the A variant on ebay was about £60 and more importantly QUICK to get as it's cold and getting something in January messes with the Christmas travels!
Am wondering if it's worth swapping solenoids or the pump motor as both look more accessible than the whole unit ???
Lee
Current :
Previous :
Also :
Old 11th December 2017, 11:13 AM
There have certainly been (inconclusive?) discussions about swapping the motors on the D2 variant. Presumably when you have the spare in your hands you can see how easy that might be on a D3.
Old 11th December 2017, 11:55 AM
I Have it in my hands. Just popped the solenoid covers off and swapping one of them would be easy. However the chances of it being failed solenoid is probably pretty slim. It doesn't really give access to the valve, more the valve actuator. You can press it up and down and see if it's stuck i guess. 5 bolt screws and one tapered as the two center ones are shared. Chance of loosing a screw, but that's probably the worst danger there!
The motor is two screws to get off. One is underneath and could be tricky whilst in the car, but also there's a mounting bracket with 4 of those carrots which probably means it supports the valve assembly, so it may be a case of it's easier to remove the valve to get to the motor.....Or maybe flexing it up may work. I'll have to investigate!
Lee
Current :
Previous :
Also :
Old 11th December 2017, 02:42 PM
To try and change the pump motor in-situ, probably best to remove the two 8mm? nuts below and retrieve them with a telescopic magnet tool or jam a shred of kitchen roll in the socket to make it a tight fit on the nut. You might then have enough slack to pull the whole assembly up or tilt it with pipes attached but I wouldn't count on it.
