If you loop out radio or amp or telephone does it go to sleep then ?
Is it only looping out the nav that makes it go to sleep .? The door handles like said can cause an issue but I just cannot see how looping out the nav could be linked ( but you never know ! ) By using a meter in line and looking at dormant current draw it gives you a clue as to what to look for ....is it a big draw or not so much On the bigger cars I use a shunt inbeteeen the battery cable and ‘ tap up ‘ off that ....it’s because when they wake up they can draw a lot of current and in an average multimeter the fuse will be blowing all the time . With the door handle buttons it’s the case that water gets in the switch and this wakes body module whilst asleep ...pulls out about 6/7 amps for a few mins at a time . If you leave the optical cable in the nav unit but unplug the power feeds plug what happens then , does it go to sleep then |
Hi guys
Ok I did a little more digging into this. Here´s what I tried/found. I went for a drive as my battery was @10% power this morning. When I parked I put in the MOST loop in order to see how much time passed before the car went to sleep after locking it. approx. 40 seconds. I then tried the same with the radio and amp. Same result. approx 40 sec. I then tried leaving it all as normal, without the loop and again 40 sec. Then I tried starting the car. Then shut it off and it never went to sleep. So now I´m at a complete loss as how to fix this. Normally when I park my car, I pull one of the fuses for either the Radio, Amp or Nav and this makes the car sleep after the said 40 sec. Thats the reason I was thinking it would have to be here the problem was. As said in the beginning of this post I had water ingress in the trunk where these units are located. The only thing that hasnt been touched as of yet, is the amp. Should I find a new unit to test this or would that be a waste of money? When I got home, I did a complete VCDS scan and this is the result. Wednesday,17,January,2018,14:58:20:14903 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.8.1.0 (x64) Data version: 20171130 DS276.6 www.Ross-Tech.com VIN: WAUZZZ4E87N024452 License Plate: DZG880 Mileage: 203160km-126237mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77 VIN: WAUZZZ4E87N024452 Mileage: 203160km-126237miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Sporadic communication error 1000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: Sporadic communication error 1000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ª0060 Revision: 5AH15--- Serial number: AUX3Z0G5325272 Coding: 01060003190F0160 Shop #: WSC 02313 785 00200 VCID: 5FCDFFD18E07ABBEC8-800A No fault code found. Readiness: 0000 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E2 910 156 C HW: 09E 927 156 B Component: AG6 09E 5,2 FSI RdW 0020 Revision: --H01--- Serial number: 0107682 Coding: 0000001 Shop #: WSC 02313 758 00200 VCID: 2447B03DE7E1C866D5-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB Component: ESP 5.7 allrad H49 0500 Coding: 0001627 Shop #: WSC 27227 000 00000 VCID: 2447B03DE7E1C866D5-8070 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G5325272 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: 58BFD4CDEB295C8689-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 3 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 150 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 16:55:14 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 149 Mileage: 203136 km Time Indication: 0 Date: 2018.01.17 Time: 13:44:26 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 2 Reset counter: 190 Mileage: 203136 km Time Indication: 0 Date: 2018.01.17 Time: 14:05:42 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 73430 210 01865 VCID: 2447B03DE7E1C866D5-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 P HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 343FK077600723 Coding: 0010002 Shop #: WSC 00000 000 08192 VCID: 397971497063A58E96-806C Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000040893 Subsystem 3 - Serial number: 0120.06.070000000100010046ÿ Subsystem 4 - Serial number: 010046ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000123359 Coding: 0041089 Shop #: WSC 02311 785 00200 VCID: 1C3788DDDF91F0A66D-8048 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0133122 Shop #: WSC 02313 758 00200 VCID: 36637A75417D4AF67B-8062 Subsystem 1 - Part No: 4E1 910 113 C Component: Wischer WWS D3 H60 0420 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 00139548 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 552 HW: 4E0 907 552 Component: 5.2L V10/4V FSI ª0060 Revision: 5AH15--- Serial number: AUX3Z0G5325272 Coding: 01060003190F0160 Shop #: WSC 02313 785 00200 VCID: 5FCDFFD18E07ABBEC8-800A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G0DVS. Coding: 0430707 Shop #: WSC 02313 758 00200 VCID: 275DA73196D7237EF0-8072 Subsystem 1 - Serial number: 63328RB402A1F5E4T Subsystem 2 - Serial number: 63428RB402A1F613H Subsystem 3 - Serial number: 63528RB402A1F64FX Subsystem 4 - Serial number: 63628RB402A1F616M Subsystem 5 - Serial number: 63729RB4027E9A29- Subsystem 6 - Serial number: 63829RB4027E9ABC6 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 C Component: J0527 0410 Revision: 00H04000 Serial number: 90055071280009 Coding: 0012141 Shop #: WSC 02311 785 00200 VCID: 2643AA3591DD3A76CB-8072 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0030 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 901 D HW: 4E0 920 901 D Component: KOMBIINSTR. VDO H82 0530 Revision: D05 Serial number: AUDID3G6001737 Coding: 0032513 Shop #: WSC 12345 001 136936 VCID: 2149B929F8F3DD4EBE-8074 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 200030752700A3 Coding: FCFEFBDC2B7104 Shop #: WSC 39586 001 104857 VCID: 275DA73196D7237EF0-8072 4 Faults Found: 00470 - Company Comfort Databus in Single Wire 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 16 Reset counter: 150 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 16:47:36 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 190 Mileage: 203148 km Time Indication: 0 Date: 2018.01.17 Time: 14:02:25 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 190 Mileage: 203148 km Time Indication: 0 Date: 2018.01.17 Time: 14:02:25 00384 - Optical Databus 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 3 Reset counter: 190 Mileage: 203148 km Time Indication: 0 Date: 2018.01.17 Time: 14:03:28 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046005 Serial number: AUZ5ZBG3422454 Shop #: WSC 00000 000 00000 VCID: 1A3B8EC5D5A58E967F-804E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G5325272 Coding: 0410624 Shop #: WSC 02311 785 00200 VCID: 58BFD4CDEB295C8689-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 3 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 190 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 16:55:14 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 149 Mileage: 203136 km Time Indication: 0 Date: 2018.01.17 Time: 13:44:26 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 3 Reset counter: 150 Mileage: 203136 km Time Indication: 0 Date: 2018.01.17 Time: 14:05:42 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 L HW: 4E0 907 553 H Component: LUFTFDR.-CDC H07 6340 Coding: 0015510 Shop #: WSC 27227 141 06276 VCID: 2C57581D8F3100261D-8078 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 73430 210 01865 VCID: 2447B03DE7E1C866D5-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H41 1060 Revision: 00000000 Serial number: 305AF037521880 Shop #: WSC 00976 210 80405 VCID: 3B756B417A5F979E84-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000716200052 Coding: 0003206 Shop #: WSC 02313 758 00200 VCID: 1D3185D9C48BF9AE9A-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 D Component: Türsteuer.FS BRM005 0180 Coding: 0032620 Shop #: WSC 02313 785 00200 VCID: 204FBC2DF3F9D446B1-8074 1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 0 Reset counter: 189 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 16:49:24 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H08 0020 Revision: 00200008 Serial number: W040706260187 Coding: 0005224 Shop #: WSC 02313 758 00200 VCID: 2A5B5E0585C51E16EF-807E Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H03 0120 Revision: PROD_01 Serial number: 00000000000948 Coding: 0000026 Shop #: WSC 02313 758 00200 VCID: 2C57581D8F3100261D-8078 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 B Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000007839 Coding: 0011101 Shop #: WSC 02313 758 00200 VCID: 1E3382D5C98DE2B683-804A 1 Fault Found: 02267 - Control Circuit for Relay for Washer Fluid Heater 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 150 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 16:43:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 D Component: Türsteuer.BF BRM005 0180 Coding: 0032620 Shop #: WSC 02313 785 00200 VCID: 204FBC2DF3F9D446B1-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000731 Shop #: WSC 27227 141 173470 VCID: 204FBC2DF3F9D446B1-8074 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 758 00200 VCID: 2959A10980C3150EE6-807C Subsystem 1 - Part No: 4F0 941 329 D Component: AFS-Modul links H01 0010 Subsystem 2 - Part No: 4F0 941 329 D Component: AFS-Modul rechtsH01 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 388EW077626170 Coding: 0000001 Shop #: WSC 31414 790 00001 VCID: 31694969A8136DCE2E-8064 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000007811 Shop #: WSC 43650 001 104857 VCID: 204FBC2DF3F9D446B1-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 351213D08A Coding: 344530393135313035412056413033353132313344303841 Shop #: WSC 43650 001 104857 5 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 18:54:14 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 19:00:39 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 19:00:55 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 19:01:05 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 203136 km Time Indication: 0 Date: 2018.01.15 Time: 19:01:15 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032620 Shop #: WSC 02313 785 00200 VCID: 1E3382D5C98DE2B683-804A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000704300245 Shop #: WSC 12336 024 394758 VCID: 36637A75417D4AF67B-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0032620 Shop #: WSC 02313 785 00200 VCID: 1E3382D5C98DE2B683-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720717005046 Coding: 0201108 Shop #: WSC 02313 758 00200 VCID: 2345B321E2EFCF5EAC-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H16 1130 Revision: 00000000 Serial number: 00000007684911 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 2C57581D8F3100261D-8078 No fault code found. End-------------------------(Elapsed Time: 03:35)-------------------------- I´m quite certain that the errors marked with RED is bacause I disconnected the MOST. The errors marked in BLUE is becasue of my low battery voltage this morning. ANY and ALL help is greatly appreciated. thnx Last edited by ChiefUno; 17th January 2018 at 01:06 PM. |
How are you seeing the car going to sleep ? Is it by looking at hazard light back lighting ?
That and the backlighting by the gearselector
Return the MOST system back to normal. I am certain that it's the handles that's causing the issues.
Also make sure that the battery is correctly coded to the car.. providing that the battery is a genuine VAG one and intended for your car.
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey |
The battery is coded and working. I´m sure that is not an issue here as I previously had it done by Audi
By returning the MOST back to normal you mean just leave it as it is right? with out the loop. But how do you explain that the car enters sleep mode when I pull a fuse? |
yes return the most back to factory specs and replace the handles.. that should cure it.
