Old 6th February 2018, 08:19 PM
I managed to get a good hose from A8parts and electrolytically de-rusted the main union. Painted it, wrapped it in self-amalgamating tape, and then covered it in adhesive-lined heatshrink. No more mud and water getting in there
Old 6th February 2018, 08:28 PM
I guessed you would be way ahead of me there MJ!
Old 9th February 2018, 12:34 PM
MJ which paint did you use? And which heatshrink?
My pipes have arrived I'm thinking its a good idea to future proof them as much as possible before installing them.
Old 9th February 2018, 02:17 PM
Ronseal No-rust Metal Paint, and then some 4:1 shrink ratio adhesive-lined heatshrink I found on ebay I did all the crimped joints with heatshrink too.
Old 10th February 2018, 09:52 AM
Thanks Mikki!
Do you know the torque settings for the pipe bolts, both delivery return and return pipes please.
My computer which has ElsaWin on it won't start up!
Is it just a bolt on job then re-fill, no complicated procedures to bleed air out?
Thanks!
Old 10th February 2018, 08:11 PM
No idea on torque specs tbh, but I'll have a look later. You can't get a torque wrench on most of the bolts anyway so I just tighten them until they feel right. Make sure you use new sealing washers.
No complicated procedures. Just re-fill and swing the steering from lock to lock until the pump quietens down.
Old 11th February 2018, 10:29 AM
Thanks Mikki!
Good point its so tight in there I wont be able to get a torque wrench in there. I'll just do it by feel.
I ordered all new washers and banjos. Just hope the old ones are not seized up.
