Old 11th February 2018, 05:13 PM
It’s the caption where 2 part numbers are called item 8. Does the wheel arch liner need to come off too?
Ah Ok, I'll need to check the online parts thingy with the parts numbers against MJs post agai n. Maybe I made a mistake and she was talking about the V6 2-part hose?? [edit; see MJs post above]
The wheel arch liner doesnt need to come off to check the condition.
Old 11th February 2018, 05:41 PM
Thanks guys. Even after many years on this forum, I still find myself amazed at how helpful (and QuickTime respond) everyone is. I know it’s been said before, but the members of this forum are absolutely essential in me being able to continue to enjoy my ‘8s.
Old 12th February 2018, 08:32 AM
I am about to dive into this, or under the wheel arch
What can I use to remove power steering fluid off the subframe and other parts?
Its probably too late it may have damaged the subframe paint already.
Is something like laundry powder or even fairy liquid ok? Or should I get a proper degreaser like Gunk from Halfords?
Thanks!
Old 12th February 2018, 10:47 AM
Yours is different, being LHD. It won't have that union - I think the hose just goes straight on to the rack. If its leaking though I presume it also has a steel piece through the wheel well which has rusted away the same as RHD versions.
PS fluid isn't corrosive - its just oil, so shouldn't have affected the subframe paint. Brake cleaner is best for stuff like that. Spray it on and it will dissolve the oil and take it away with it without damaging anything. Something like this: https://www.ebay.co.uk/itm/HOLTS-PRO...UAAOSwx6pYpbAt
Don't use carb cleaner or tar remover as they are too aggressive, or laundry detergents as they are generally alkaline and not good for aluminium! Gunk is very effective, but the smell is dreadful and lasts for ages. It also eats driveways! A mild engine degreaser would also work.
Old 12th February 2018, 11:01 AM
Thanks Mikki, good advice I will keep laundry powder well away from the car
Yes on my car the delivery pipe is one piece. Looks like its well protected (crimp joints covered by thick foam rubber) and already painted.
Only the return hose has the crimp joints exposed.
I found this not-so-good site which has some D2 manuals on it. Seems that the banjos on the pump are both 50nm so need to be quite tight. I couldn't find settings for the ones on the rack end but I will assume 50Nm also as one of them is high pressure.
The high pressure hose bolt on the pump is a real pain, the hose fr the reservoir is in the way. I'll have to loosen it and move that hose to get to the bolt.
http://workshop-manuals.com/audi/s8_...iew/page_3803/
Its funny how when doing something else you find unrelated things. I think I found my gearbox oil leak. The hoses/pipes look good and dry all the way to the radiator. But on the gearbox one of the banjo bolts appears to be missing a washer, and that pipe and bolt are covered in oil. So that's my next job, to replace that bolt or at least the washers. At least it looks like I dont need the out of production hoses! for now...
Old 12th February 2018, 11:08 AM
Found the info for the rack banjos on the above site. Weirdly the high pressure hose bolt is 40Nm, the return hose bolt is 50Nm.
Oh well, who am I to question Audi instructions
Old 12th February 2018, 01:14 PM
Could be because they are different size bolts so they want different torques to get the same clamping pressure on the crush washers
