Old 15th February 2018, 05:51 PM
I do think that the F125 switch is prone to failing more quickly if you dont do much mileage or use the car every day or two. Mine was new with the factory exchange gearbox and had only done about 20,000 miles but it felt like one of the prongs inside had almost welded itself into the contact plate so that when it was moved it snapped off - totally sympathize Brian
I agree with that - mine was just fine till I stopped driving Herman regularly
Old 15th February 2018, 06:27 PM
Having opened up mine after its failure, it isn't surprising that both lack of use and, eventually, wear over the 100k miles lead to failure. Its an old-fashioned, electromechanical piece of kit where copper, brass alloys and electricity mix. The lubricating grease gets swept away leaving contacts on the copper strips when not used.
Old 15th February 2018, 06:34 PM
Lack of use could be a factor in my case too. Thinking about it I havn't really had any big bills other than routine maintenance, tyres, brakes etc for a few years so probably can't complain. Drove it into Glasgow earlier to drop a tyre off with Tintin..and it just reminded what a wonderful car it is
Old 28th February 2018, 07:38 PM
F125 Switch and "mini service" carried out today, so S8 fully functioning again, do hope I am not tempting fate Excelled itself on way back from mechanic, easily passing lesser cars stuck on the hill in the snow with the style and panache that only an 8 can Should be ready for it's NC500 trip at the end of April now
Old 1st March 2018, 06:23 PM
Regulus Regulus is offline
Best of luck, good to hear it turned out good
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
