For Sale and Wanted - Cars For the sale of whole cars, Audi or not, working or not. No cross links to other peoples cars please - Use Spotted online instead |
For Sale Audi S8 2002
Good bits: 81,000 miles MOT till Sept 2018 Bodywork in great condition for the year, only the odd blemish here and there Xenon Lights Sat Nav Immaculate interior New brake pads and rear calipers Gearbox perfect Oil change less than 500 miles ago Battery 18 months old Plenty of Service History Bad bits: 1. Car is suffering from an overheating issue. The temp gauage will continue past 90 degrees which I know is not normal as it usually sits bang on 90 degrees. Have only driven a short distance so have never even gone to 100 degrees. Car heater stays warm. 2. Cracked windscreen 3. The roof needs to be resprayed as the lacquer has come off due to a car cover in combination with freezing weather 4. Central locking seems to be temporamental. I can pair the key with the car, but it seems to unpair a few days / weeks later. 5. Parking Sensors do not work. It is the front drivers side that is faulty. Because of the overheating issue I wouldn't recommend driving much of a distance so will need to be towed away. Hence sold as seen / spares repair £1895 ono Car is located in Rutland. For for info call 07720851128 |
Welcome to the forum. We have another member quite near you (near Belvoir)
At that mileage it surely deserves to be fixed, nothing sounds too horrendous for the right enthusiast. So hopefully it won't be scrapped. Overheating could just be a faulty CTS, or worse thermostat (bit of a PITA to swap). It surely must have some extras not listed above. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st February 2018 at 08:26 PM. |
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ![]() ![]() (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ![]() (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
Hi,
Thanks for the reply. Thermostat has been done, genuine Audi part. Hence the ad. I'm not getting any erratic temps hence why not convinced its the CTS? Just a steady rise higher and higher. Also I let the car idle for 15 mins after replacing the thermostat. Bang on 90 degrees. Only when I began to drive it crept over 90. Are they hard to replace? Cheers. |
Quite easy (and cheap); bit fiddly and care is needed to ensure you don't lose the clip down in the engine bay.
I posted a thread ages ago on how I did mine, will link to it if I can find it. It's still fine over 4 years later. Edit, no I didn't, I just added to this one; read it all (post 17 is my initial summary): http://forum.a8parts.co.uk/showthread.php?t=1157 Getting the plug off seems to be the biggest problem.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st February 2018 at 09:07 PM. |
Has it ever had a timing belt? What can happen is the hydraulic belt tensioner fails and allows the belt to go slack on over-run. When that happens it stops driving the water pump so no coolant flows round the engine and it over heats (had one in like that last year). Worst-case scenario when the belt snatches the pump on acceleration the torque spike loosens the impeller (cast iron on these so lots of intertia) and after a while the impeller simply falls off the shaft. That happened on mine (before I got it!).
If you do want to persever with it, I'd suggest a genuine exchange water pump and INA timing belt kit with the tensioner (essential) would sort it right out, but that's not a cheap job. |
Yes it has has a new cambelt according to the service history. The reason I don't suspect any water pump issues is that the heater works? Doesn't one not get any hot air if the pump isn't working?
There is an auxiliary (electric) coolant pump as well that moves coolant through the heater matrix. Same pump moves coolant for the "AUX" heater function with the ignition off.
The ACP famously has a motor that can get very noisy, the solution to which is to disconnect it! I have done that on both my S8s. Remember the CTS has two sensors in it, one drives the display on the dash, the other gives information to the engine ECU, so what you see on the dash doesn't necessarily mean anything. VCDS I think can read both.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st February 2018 at 09:29 PM. |
pretty sure i test drove this car when i was looking to part exchange my abarth
![]() it was the car listed on this site below, then it went to auction? it had the c/c black bits, put me off because the airbag light was on, now i realise an easy fix, FSH at Audi, went well, a few dents as well https://www.my-next-car.co.uk/
Audi S8 D2 #ronin ![]() Abarth 500 Esseesse - Sold RS6 Avant Black - Stolen ![]() Mercedes Benz CLS 500 - Sold Corsa VXR Nurburgring - Sold RS6 Avant Grey - Sold Seat Leon Cupra R - Sold Last edited by RS6; 21st February 2018 at 09:49 PM. |
Yes that’s right. I took vcds with me to the garage. Was the seatbelt tensioner, fixed for £25. I had time and money to fix back then. No dents now that I have really noticed?!
