Old 1st March 2018, 07:46 AM
There is a special (ie expensive) machine which can extract broken plugs without removing the heads. Might be worth calling round some diesel specialists to see if they have such a thing, and take it there rather than trying to diy it.
Old 1st March 2018, 08:39 AM
Oh the irony....
I'm expecting a visit from a mobile mechanic with such a special machine next week to rescue my 4.2 Tdi
On the plus side, they are quite easy to access, unlike some engines.
4 glow plugs reporting as faulty in the ECU.
Really poor cold weather starting (unsurprisingly)
Decided to swap all 8 (regret that now tbh)
4 swapped over ok.
1 has disintegrated shearing off the head completely and leaving the tail stuck in the head, although technically the head is still sealed which is sort of a bonus.
1 came out ok but has totally mashed all the threads (not so good)
1 is unscewed but refuses to come out (and we're reluctant to force it)
1 is unfeasibly, self destructively tight.
We did eventually find one guy who seems to make a healthy living from doing nothing else than recovering diesel blocks with stuck glow plugs and injectors.
If you're going to do it, lubricate the hell out of the things first, but that's very little guarantee of success it seems. Take it to someone you trust to (a) do it right and (b) sort it out if it goes badly.
Or (c) Buy a petrol lol
Old 1st March 2018, 08:53 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Jeez. Knew this wouldn’t be an easy job, but didn’t realise it would be quite the issue it is.
Can penetrating oil be applied well in advance? Have you seen those tools that rapidly heat up nuts and bolts? Like a kettle element crossed with a mig welder? I’ve seen those used to great effect on old car restorations. Wonder if that process could be adapted/used...
Edit: the tool is a commercial heat induction jobbie.
P.S. I think I’m right that glow plugs in TDi’s are used all the time the engine runs, not like they used to be on older diesels. What if anything, happens if you have a plug not functioning when driving? My sister’s C6 A6 four pot has had a faulty glow plug since she bought it a while ago. Starts and drives fine.
2007 Mini Cooper S R56
Old 1st March 2018, 09:23 AM
You're halfway right ^. The heat element is used for start, and some afterglow when its cold. In most commonrail engines the glow plugs are also used to measure the pressure in the cylinder:
1 Plug
2 Circuit board with electronics
3 Glow plug body
4 Glow plug heating rod
5 High voltage connection
6 Measuring diaphragm
7 Gasket
There are a few articles on using the glow plugs to measure ionic conductivity of the combustion process, but it seems the pressure sensing is what the OEMs settled on.
An induction heater might loosen the plug if you can get it in there - thats worth a try if you can borrow one
Old 1st March 2018, 09:25 AM
Johnmed's Avatar
You're halfway right ^. The heat element is used for start, and some afterglow when its cold. In most commonrail engines the glow plugs are also used to measure the efficiency of the combustion process while the engine is running via ion conductivity of the cylinder contents (ie magic). If you have a single wire going to the plug then its just a heater, but if there's a multi-pin connection its an ionic one.
Ha. Thanks for the clarification.
So I’m halfway wrong too....
Old 1st March 2018, 09:47 AM
I was halfway wrong as well! Ion sensing was proposed, but it seems no one has put in to production, preferring pressure sensing instead which much be close enough but cheaper. See the edited version for the correct info
Old 1st March 2018, 11:02 AM
Joe2.0E Joe2.0E is offline
A8 TDI Glowplugs seem to extremely prone to failure. The Service History indicated that my D3 had all 6 replaced twice over a 5 year period before I bought it. Over the next 5 years that I had it, almost all were replaced again and some of them twice.
Tags
asb, glow plugs
