I did note other RPM : speed ratios during the same test.
'09 D3 S8 - Most of the bells and whistles (B&O, Audi Exclusive brown interior and exterior paint, soft close, ACC etc) de-flapped manifold! |
What a great thread!
I agree with a lot of the posts on here. I'd definitely like the PDC and mirror dimming to be switchable. The latter with a simple button rather than the MMI. I'd also like to check my PAS fluid without dismantling anything. A cooled glovebox is an absolute must. I'd also add that I'd like the fuel computer to be 'of this century'. I have a 1994 Vauxhall Cavalier and the computer in that is much smarter than in the S8. The range isn't limited to 5-mile increments and it shows you the consumption at idle, rather than the last consumption while moving. I wish the adaptive cruise could be set to individual speeds, rather than in five-mile increments. I'd like a soft-touch steering wheel because mine is horribly slippery. Come to think of it, steering with some feel at all would be nice. I'd like a mute button on the steering wheel. I wish they didn't stop designing the rear brake calipers with the ceramics. They look so pedestrian compared to the front! I wish the armrests and ledges on the door cards were softer. After a long trip, I find my elbows ache. In fact, a lot of the interior materials feel a little hard for my taste. I wish the indicators in the tail lights used the inner lights as well as the outer lights. I wish Homelink was standard fit on all cars. Even if you don't have a garage, you can hook it up to all sorts! I wish the electric side blinds also covered the rear-quarter window. Although I don't want to delete the dipstick, it would be nice to have an oil level (and age) indication inside. I wish it had electronic flaps in the exhaust, rather than the vacuum-driven ones. I'd like to be able to choose how loud I want the car and not feel like I have to plant the throttle just so the inner pipes get used. (yes, I'm a little OCD) I wish it had cylinder-on-demand, so it would pootle around town as a V6 or V4 and fire up the rest when needed. I wish you could set engine modes as well as gearbox and suspension. I wish it had more low-down torque. I love that it can rev so high (and sound that good doing it), but I wish it didn't have to rev that high. Speaking of revs, if you're going to make a car that sounds that good revving, let it rev all the way into the scary numbers! I wish the indicator stalks were more fitting to a luxury car. I was surprised how cheap they felt. Speaking of indicators, why do the fronts have halogen bulbs when virtually everything else is LED?! While we're getting rid of halogens, bin the halogens in the rear foglights and reverse lights. I wish they all had illuminated side sills. I wish the instrument binnacle didn't have those little gaps between the clear plastic screen and the cowl (try un-seeing that now!). I wish the drinks holders... held drinks?! I wish the card holder was useful, but I do love how the little LED turns off when it's opened! I wish the auto bootlid didn't feel/sound like such hard work. Other cars open so much more quietly and close so much more gently. I can feel mine thud closed through the ground! And what's with that horrible high-pitched whirring noise it makes at the last stage?! It sounds like ED-209 from RoboCop! I wish the B&O was more customisable. It has too much mid for my taste. I wish the volume control had numbers. The B&O sounds epic at one particular volume setting, but I always end up having to change it because people insist on wanting to... talk. Then, I have to trial-and-error it until I've found it again. I'd love a panoramic roof. Heck, I'd settle for a sunroof! Finally, I wish there wasn't that delay before the car does anything. Whether that's using the menu, turning on the heated seat, or even braking and accelerating. It feels like the car has to stop to process the input before acting on it. You're right, this is like therapy! |
Great list Tony, bet you had to have a little cry of relief afterwards!
And you’re right about the drinks holders, in fact you’ve just reminded me I need to buy a new plastic inner, all the spring loaded tabs are broken in mine which doesn’t help.
Don't hold back!
![]() Personally there isn't much I can think of that I would like differently, although as mentioned earlier in this thread a battery voltage which I miss coming from a B5 S4. One thing I would prefer is the seat control being somewhere easier to see what they are doing. It's fine when you know which one does what (although I think my lumber one has been put on wrong since it doesn't correspond with the movement) but when a new passenger gets in and wants to adjust it, it's not the easiest thing to try and explain!
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
Good list Turbo Tony.
I agree with the trip computer - my 1997 Vauxhall Omega was much better, and then my 2002 VW Passat. The DIS in general looks like a rushed design with poor typography and badly translated messages. All that space and you get Brake Pads! or Select P when parked or vehicle may roll away! I also wish that the steering wheel controls were just +/- </> buttons rather than these thumbwheels that overshoot. On Vauxhalls, they had those and you could just count the clicks to move to a particular track without looking at the screen and then thumbing back and forth. |
The B5 Passat had a cooled glovebox - the only model I know of that era that did, even though the A4 had the same heater box with a grommet over the cold air hole! I retro-fitted the Passat ducting to my last A4.
I wish the D2 had stereo remote controls available on the 3-spoke wheel rather than just on the ugly 4-spoke. I'm going to re-task my tiptronic buttons for track and volume up/down when I do a manual swap. |
Is this a real thing that can be done?? I never use my Tiptronic buttons because my 2.8 Quattro Sport just isn't sporty enough. I just waft along, quite happy with the auto so I'd love to make use of those redundant buttons. Steering wheel stereo controls are the only thing I really miss in Big Red. Have you seen any documentation on this online? (I have a Symphony II and not the RNS-D as you may be aware ![]()
Dean Future work on "Red Dwarf": Fridge, solar sunroof, radio-controlled clock, interior and exterior dimming mirrors, Alcantara headlining/pillars/rear shelf, rear US outer lights, passenger memory seat, rear electric (lumbar and headrest) heated seats, Servotronic. __________________ Current: 2002 A8 D2 S8 FE - "Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras 1st Place Winner - A8Parts Annual UK Meet 2018 1st Place Winner - A8-Freunde Annual German Meet 2018 2nd Place Winner - A8-Freunde Annual German Meet 2019 2002 A8L D2 with a factory fitted S8 engine and drivetrain - "Evergreen" - Irish Green Pearl (TBC) - magnolia leather seats with magnolia door cards/door trims, magnolia leather head-lining, extended leather pack 3 (dark green leather dash, upper door cards, steering wheel, lower dash, centre tunnel and rear parcel shelf), factory black external trim (in lieu of chrome), self-levelling suspension, Servotronic, Brembo brakes, "gullideckel" / "man-hole cover" / "pie-plate" 8Jx18 polished 10-hole design wheels typically seen on the W12, Park Distance Control, heated windscreen, multifunction steering wheel, Vavona burl (burr-walnut) wood inserts with cream/magnolia door switch trims, phone preparation to the front with Nokia 6091 phone, phone preparation to the rear with Nokia 6091 phone on the central rear console, third phone preparation in the rear centre console, rear blinds, rear headrest release feature, rear electric heated seats with lumbar and recline function (the rear passenger seat has the facility to move the front passenger seat forward), BOSE audio, Rear Screen Entertainment (RSE) with dual factory fitted Alpine screens, integrated DVD player (under the centre of the rear bench with 4 DVD storage slots) and two remote controls (the controls and inputs for the RSE are in the rear centre console and the screens can operate independently of each other,) factory supplied leather headrest covers to hide the rear screens, rear vanity mirrors (standard A8L), dark green rear wedge footrests with cream piping, front passenger memory seat, dark green floor carpeting and mats – piped in cream, rear slumber pillows for the headrests, integrated fridge with integrated tumblers inside the rear centre headrest bar compartment, solar roof, auto-dimming interior and exterior mirrors, factory driver’s seat fire extinguisher, tire pressure monitoring system, first aid kit, 12 V socket in the boot, TRACKER, derestricted – top speed is 155mph plus 2007 A6 Allroad C6 3.0TDI Quattro - Highland Green (Audi Exclusive Colour) - Cream leather interior with Wood, Advanced MMI, Keyless, Bose, Advanced PDC, Sunroof, Heated Memory Seats, Adaptive Xenons, Adaptive Air Suspension, Servotronic Previous (went to good homes): 2002 A8 D2 2.8 Quattro Sport - "Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering 2002 A8 D2 2.8 Quattro Sport - Aqua Blue Pearl - Twist Interior, PDC, Sat Nav Plus with BOSE, Multi-changer, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, Avus Wheels Last edited by Spanker; 26th March 2018 at 12:51 PM. Reason: . |
I've never seen it done, but I'm confident that it can be. Mine is fairly easy as I have an aftermarket stereo so I just need to wire the tip buttons up to a JVC remote control and job done.
For a Symphony or RNS it would need the multifunction steering wheel module to be installed under the dash (it won't physically fit in the 3-spoke steering wheel) and the tiptronic buttons hooking up to whichever functions you want. The tip buttons are wired in parallel as standard but from memory there are enough free contacts on the clock spring to get them out individually. Hook the module up to the canbus lines and it'll talk to the radio just as if it was a proper multifunction wheel. |
![]() Tractors and combines have them, some big enough for a huge amount of food and cider I'm sure the luxury car market will catch up soon ![]() Disco and rangie had options I think also alfa 156.
Cor blimey MJ, you don't half start my two brain cells working overtime.
A cold air outlet on the heater box!! Wonder if that was repeated on the D3? Somewhere to keep Gwen's choccy solid.
